Supra MAF in a S/C'd '96
Originally Posted by garrett1478
there might be a problem swapping in the supra MAF into 99+ 4runners. i've swapped an airbox + MAF between a 99 and 98, and it caused a CEL on both trucks IIRC.
maybe just the wiring is in a different order, i have no idea, i didnt bother trying to figure it out.
something to keep in mind...
Marks mod will be plug and play for 96-98s only (you'd need to rewire for use in later models).
Hey Mark,
Have you been watching your MPG? I imagine its bad now bcuz power can be intoxicating. I'd be interested to know how things are when you get through a few tanks of driving normally. This mod sounds so tempting right now.
#25
Originally Posted by Oscar
Hey Mark,
Yeah, but I also just replaced the tranny and put in a high-rev torque converter which dropped my mileage by about 2mpg. I just filled up yesterday... 13mpg. Before the TC I was "adjusted" to being okay with the high 15's. ugh.
Now, I had recently done a Seafoam hit, so I figure I need to replace my plugs, and my A/FR meter is being weird so it may be O2 time as well. I'm not convinced that the TC cost me 2mpg, but it _seems_ to have.
I haven't been through a full tank with the new MAF yet. I'm sure it won't be pretty.
#26
Originally Posted by midiwall
Hey Richard!
Now, I had recently done a Seafoam hit, so I figure I need to replace my plugs, and my A/FR meter is being weird so it may be O2 time as well. I'm not conviced that the TC cost me 2mpg, but it _seems_ to have.
#27
Originally Posted by 914runner
13MPG on Premium, GULP!
I have my first trail ride in about a year on Sunday - it'll be interesting to see what 6mpg feels like. ARGH.
#29
Originally Posted by 984RNR
Did any one ever figure out if this helped on an N/A Motor
But I figure I might need to upgrade my injectors, since everyone that has done this upgrade had to get bigger injectors you would probably need to do the same to a N/A motor, just a step above stock, not the huge injectors SC guys are running.
#30
Alright, heres a NooB Q: If I was to upgrade to the 305cc Toyota Supra injectors, do they always flow 305cc or UP to 305cc for when that much volume of fuel is needed?
I would think that if they were always flowing 305cc, it would kill my gas milage and would be total overkill. But if they flow up to 305cc, it couldnt hurt to put them in there when I try the Supra MAF?
Thanks
Thanks
#31
Thanks
Thanks
#32
Somebody has told you that you will NEED to have some sort of ECU managment to use the Supra MAF right? There is a good write up on why over at TTORA let me see if I can find it real quick.... This isn't the exact one I was thinking of, but should be enough: http://www.tacomaterritory.com/forum...15&postcount=4
#33
Alot of people run the SMT, so thats what I would get.
#34
eheheh you finally got it!
I have been using the supra maf for 3 years now
I had a old dyno which proved a 10whp peak through the whole entire band in gains...i am going nuts searching for the dynos!
The stock maf with the s/c is at 96% capacity with the stock pulley, with the supra maf i recorded at full throttle and 9.5psi to be 85% full (smt6
I cant believe i almost put on 100,000km on the supercharger/smt6 setup truly awesome (altho my s/c nose drive needs to be rebuilt soon)
)I cant believe i almost put on 100,000km on the supercharger/smt6 setup truly awesome (altho my s/c nose drive needs to be rebuilt soon)
#35
#38
hahaha
I wonder if there would be an improvment?
If things go my way here (in shop dyno) i will have plug and play solutions for the smt6 and 7 both pretuned.
if i do get this dyno, definatly come on up and we can tune your truck for as long as it takes. See what differences we can get with our setups.
#39
hahaha
