Supercharged 3.4 lean condition
Old Aug 12, 2023 | 07:32 PM
Rossgm1's Avatar
I know this is the wrong area for my truck ( 2g 1991 4runner) but I have 3.4 swapped it and recently added a gen 1 TRD supercharger (stock pulley) I’m having an issue with a lean condition. A couple times I did a WOT pull and got the optimal 12.4-12.6 afr but that is random because most times i try the computer seems like it does not want to give it more fuel and itll stay at like a 14.5. Which is bad lol. No codes. Just seems like the ecu doesnt want to give it fuel sometimes. And yes i swapped out the 32yr old stock pump with a walbro 190 because the stock 2g fuel pump is only like 70lph or something. Could it be vacuum to my fuel pressure reg is wrong? Any help is appreciated.
Old Aug 13, 2023 | 05:20 AM
Malcolm99's Avatar
I thought the solution was either 7th injector, Supra injectors, and or SAFC, I believe all who put on a SC experience a lean condition during WOT under the right conditions.
Old Aug 13, 2023 | 08:09 AM
Rossgm1's Avatar
Think I may have found it. Under WOT the throttle body is open 100% but the tps is reading 72%. Could that be the culprit?
Old Aug 13, 2023 | 06:03 PM
Rossgm1's Avatar
FIXED!!! Intake leaked at the throttle body made a new one and used new couplers and she boosts just fine now!
CadenB
Nov 8, 2020 05:35 PM
GREEN4SKIN'R
Dec 23, 2014 06:54 AM
toyotanick
May 20, 2012 07:12 AM
hross14
3.4 Swaps
14
Jun 1, 2009 06:46 AM
AJatx
21
Nov 13, 2006 03:16 PM
