Super Chargers Are Over Rated
Old Dec 11, 2004 | 04:33 PM
Bumpin' Yota's Avatar
Finally I fail to see how it is not cost effective/safe/cool/etc to run this in relation to superchargers. Both require fuel delivery upgrades (injectors, pump, FMU), both require new exahust, both SHOULD include charge air intake cooling (BIG minus for the TRD), piggy back smt6/7, and LOTS of dyno tuning....
Old Dec 11, 2004 | 04:51 PM
kyle_22r's Avatar
i never really saw "it takes power to make power" as such a bad thing. if you end up with 50% more power in the end, who cares?
Old Dec 11, 2004 | 05:07 PM
CynicX's Avatar
Originally Posted by Bumpin' Yota
Actually you will only have backpressure if you use the incorrect exhaust turbine and housing. If you select properly there will be NO back pressure in comparision to your stock exhaust. Back pressure is not turbo lag, turbo lag is the time it takes the turbo to spool up. Totally different concepts....
backpressure is the amount of pressure in the exhaust pushing back, its impossible to have NO backpressure with a normal exhaust system (at least anything that would make sense to have on your vehicle)....what he is saying, adding a turbo into exhaust adds a restriction, thus adding backpressure...if there was no backpressure there would be no pressure at all....the turbo needs pressure to turn...
Both require power to make power, its psychially impossible to make power without doing anything.....well at least according to science
Imagine it this way, to have a none measureable amoutn of backpressure with an exhuast system it would have to been really really big, like a foot in diameter. So if you had a turbo in that it would never move, at least enough to make power. Back pressure, unlike some people like to think, is NOT required and the less amount of backpressure the better. A turbo is by far more effecient but it still take power to make power....
Old Dec 11, 2004 | 05:30 PM
CynicX's Avatar
Originally Posted by denverbikeguy
I've never heard a "horror story" related to the TRD superchargers. Not one. And if there were any major issues, you can bet they'd be discussed here.
Take your turbo-pimpin' somewhere else n00b, try adding something of value to the forum before trying to get money from it.
there is alot of ping/knock issues trying to get the most power out of it. Usually lack of fuel mods....
Old Dec 11, 2004 | 06:22 PM
  #25
true enough, a gain is a gain is a gain, but....
Why not gain 25% more power at the same stress level on the engine?
Assuming you dont have charge air cooling on the turbo (just like a roots supercharger) both may cram the same mass of Oxygen, Nitrogen, and Fuel into the cylinders... Where the supercharger looses is in the drive system... So for any given stress level on your engine the turbo will produce more power.
Old Dec 11, 2004 | 06:58 PM
  #26
kyle_22r's Avatar
easy, on a typical lawn mower the blade is attached to the output shaft of the motor
Old Dec 11, 2004 | 07:00 PM
  #27
Originally Posted by K'sToy
IM SO LOST!!! Myabe its cuz im 15 and dont even kno how a lawnmower works
hehehehe it's all cool.
T04 refers to the housing catagory or a family of turbo chargers all using the same housing size.
The 76-P trim turbine refers to a 76mm diameter with a specific pitch to it's blades. Of the 76mm turbines there are O, P, and Q trims with O being the earliest spooling of the 76s and the Q being the latest spooling given the same flow rates. (turbines go in the exhaust path and are connected to the compressor wheel so the exhaust gasses spin the turbine which spins the compressore wheel)
The T04e-60 denotes a specific compressor wheel which would be closely suited to the needs of a 3.4L or so, but also flows a good amount of air...
The a/r size designates more or less where the exhaust gasses will hit the turbine blades. A high a/r such as .84 will take a while to spool yet flow a great deal of gas... A low a/r such as a .53 will spool very quickly in comparison and be somewhat restrictive on the top end for flowing gas...
Old Dec 11, 2004 | 07:03 PM
  #28
ps
BOV - Blow Off Valve, basically vents the boost off when the throttle plate on the throttle body snaps shut. This way the compressor wheel is not damaged by surging. (air going the wrong way in the turbo)
Wastegate is a bypass on the exaust side that keeps the turbine/compressor wheel from overspooling and exploding. Basically when a certain boost is achieved, the wastegate opens allowing exhuast gas to bypass the turbine keeping it from overspooling. If you choose the wrong size for a given flow rate of the engine, you can overspool the turbine/compressor and will grenade it the first time you revv the engine...
Old Dec 11, 2004 | 07:35 PM
  #29
CynicX's Avatar
In my opinion, it really depends on what your looking for. A turbocharger is more efficent, but it also has lag. A supercharger doesnt have lag but isnt as efficent. In a truck application, might towing, hauling, off-road...I prefer a supercharger, since alot of the time I'll need power all over the RPM range. If you want it more for a racing application then you'll probably be better with a turbo charger.
I dont think TRD's supercharger is over rated. I'm not sure, whats it had alone, 75 HP? Thats a 40% power increase, add the seventh injector kit too the supercharge, that will give you 110 HP over stock, which is a 57% power increase. I think that is a good amount and people actually under rate it.
On ebay you can pick up a TRD Supercharger for 1800, 2800 with the seventh injector kit. Install by a dealer and it wont void your warrenty. Although thats expensive you can keep your warrenty.
Old Dec 11, 2004 | 08:07 PM
  #30
OOC what is the 7th injector kit all about anyway? I also see it advertised on eBay for 99+ or 2000+ V6, that sort of thing. I have a 97, which in theory anyway is the exact same motor. Is there *any* reason an s-charger or 7th injector (whatever that is) won't work for any year of 3rd gen?
Old Dec 12, 2004 | 07:03 AM
  #31
FilthyRich's Avatar
you can s/c any 3rd gen 4runner. If you are looking into fuel management, for the money the URD kit is superior. At least if you want to be able to tune your vehicle. The 7th injector kit is a fixed unit you cannot program or adjust
Old Dec 12, 2004 | 08:24 AM
  #32
Ok, but again what does the 7th injector do? Is it just something to muck with the ECU signals, or ?? What's the URD? (Just asking since these are new things to me, but an S/C may be in my "6 months from now" future)...
Old Dec 13, 2004 | 06:36 PM
  #33
Mulkey's Avatar
http://urdusa.com/ This will answer a lot of ur ?'s.
kawazx636
Oct 6, 2021 03:03 PM
4x4YOTA
Aug 23, 2016 09:08 AM
punks_is_4x4
Feb 26, 2016 04:29 PM
smilen724
13
Nov 8, 2015 04:11 PM
Chicken12
Oct 14, 2015 03:54 PM
