Stuttering in Low RPM
Old Feb 27, 2005 | 12:04 PM
Mig750's Avatar
Any suggestions before I take her to the stealer. I have started getting a very obvious hesitation and lack of power below 2000 rpm and on 1 or 2 occassions some ping and back fire. It is less obvious above 2500 rpm but I do feel it especially in higher gears. It just started like 2 weeks ago. Now I have about 95k miles on her and I probably need new plugs/clean throttle body, pvc valve and a new fuel filter. I changed the air one. Since this stuff is all computerized do you think it might be something else like ex. O2 sensor? or another sensor?
Old Feb 27, 2005 | 02:14 PM
MTL_4runner's Avatar
My bet is that the hesitation is ignition related (ie either bad plug or an arcing ignition coil). I would still do as you mentioned "clean throttle body, pvc valve and a new fuel filter" and O2 might help you run smoother with better gas mileage, but I would say ignition first to fix the miss.
Old Feb 27, 2005 | 04:10 PM
Mig750's Avatar
Yeah thats what I thought change the plugs first and see what happens from there.
Old Feb 27, 2005 | 10:36 PM
EWAYota's Avatar
also, check the egr valve and tps as well
Old Feb 28, 2005 | 03:55 AM
No EGR on these motors, but good call on the TPS.
Old Feb 28, 2005 | 05:19 AM
Mig750's Avatar
wHAT IS THE TPS?
Old Feb 28, 2005 | 06:25 AM
wHAT IS THE TPS?
Throttle Position Sensor (TPS)
.....there are other meanings such as in the movie "Office Space".
Sleaker
Aug 26, 2020 06:03 AM
Jdgarrison
Oct 1, 2015 05:22 PM
tinigunner11
Aug 14, 2015 01:19 PM
