stuck shifter...
Old May 31, 2005 | 09:01 PM
96LtdYota's Avatar
Exclamation stuck shifter...
i know i know, i should drive a 5speed.... but this is what i got.
so the other day i jump in and try to shift and nothing happens. so i get fed up and use the little shift override button thingy so i can shift... so everytime i want to put it into drive, i have to press the little button thing... does anyone have a clue as to what i could possibly do to fix this...
thanks as always yt people...
beaux
Old May 31, 2005 | 09:07 PM
superjoe83's Avatar
are your brake lights working? check the fuse...
Old May 31, 2005 | 09:17 PM
96LtdYota's Avatar
no, they dont... why would this cause the shifter to not work...
Old May 31, 2005 | 09:32 PM
EWAYota's Avatar
might have something to do with automatics having to have the brake pressed to shift into drive....fuse might be tied together???
Old Jun 1, 2005 | 04:22 AM
rngrchad's Avatar
Underneath your rig, there is an automatic shift linkage adjustment. 4Crawler shows pictures on his website. If this linkage somehow moved it may be binding and thus not allowing you to shift. On my tacoma, the linkage is on the driverside of the transmission. I think a 12 mm loosens it up. Just play with the adjustments until you find something that works....I had to have someone else to work the shift lever in the cab. Good luck...
Redeth005
Jun 28, 2018 08:16 PM
rubrsidedwn
Jul 7, 2016 07:28 PM
spiewaker
Dec 16, 2015 01:10 PM
BK2TFUTURE
Oct 11, 2015 08:42 PM
Obmi
Sep 24, 2015 08:10 AM
