Stereo dudes: Keeping the antenna down while the CD player is on
Old Nov 25, 2003 | 11:32 AM
rimpainter.com's Avatar
Question Stereo dudes: Keeping the antenna down while the CD player is on
On my old Alpine, the antenna would lower when the CD player was on. Then it would raise when the radio was turned on.
On my new Pioneer, this does not happen. The antenna stays in the up position if the head unit is on - no matter what.
When I removed the nest of wiring from the previous owner, there was a yellow wire with a large black box in the center. This was wired in to the yellow lead from the Alpine radio. When I installed the Pioneer, I purposely left this off. Does this have anything to do with my power antenna staying up?
How do I get the antenna to go down when the CD player is on? My main reason for doing this is when I am off-roading and listening to a CD.
Thank you.
Old Nov 25, 2003 | 11:58 AM
ugadawg95's Avatar
i had the exact same problem with a previous head unit that happened to be Kenwood. However, on my new Alpine 9813, the power antenna goes down when the CD function is selected. I know I had a power antenna lead on the new head unit when I wired it to the factory harness. Did you have a blue power antenna lead on the pigtail included with the headunit?
Old Nov 25, 2003 | 12:04 PM
Yes. Maybe this is Manufacturer dependent...
You would think that the head unit would just send a power ant down signal if anything other than the radio was selected.
Hmmm, maybe I should read the instructions for once in my life.
Old Nov 25, 2003 | 12:10 PM
ugadawg95's Avatar
what Pioneer model did you get?
Old Nov 25, 2003 | 12:12 PM
the_supernerd's Avatar
Make sure you did not mix up the power antenna lead with the amp turn on lead. Some head units use the same wire, others have a seperate amp turn on. It is also very likely that retracting the antenna could be manufacturer specific, if that is the case then a good option would be to install a switch in the power antenna line. Then when you are wheelin' you can retract your power antenna while you listen to CDs.
Old Nov 25, 2003 | 12:15 PM
DEH350P "Premier"
Old Nov 25, 2003 | 12:16 PM
Good idea.
Old Nov 25, 2003 | 12:24 PM
SLC Punk's Avatar
Not that it will help you now, but I know for a fact that it is stereo dependent.
Old Nov 25, 2003 | 12:27 PM
Well, that does help. It prevents me from going in and tearing out some wiring and re-soldering.
Thanks. So do you think a switch would work too Travis?
Old Nov 25, 2003 | 12:32 PM
SLC Punk's Avatar
I don't see why it wouldn't work. I have thought about doing it myself.
Old Nov 25, 2003 | 12:33 PM
Denk's Avatar
I too am frustrated by the fact that the antenna won't stay down when yer only playin a cd. but would be just that simple, as splicing in a 2 position switch to the antenna power lead? That would be preferable to going in behind the dash and finding the right wires to re-connect. Do i smell a write-up?!?!
Old Nov 25, 2003 | 04:24 PM
It should be that simple. My cousin did something very similar on his Jeep Commanche with an Alpine stereo. His amp turn on/power antenna wire was not working so we just put a switch on the wire going to his remote turn on his amp. It has been working just fine. Besides, the power antenna wire is always disconnected if it is installed in a vehicle without a power antenna. It makes sense to me.
Old Nov 25, 2003 | 05:03 PM
smr4runner's Avatar
Hmmm?
I too have the 9813 and my antenna stays up when the CD is playing.
I was just checking it last night.
So you used the factory harness. My problem may be from the aftermarket harness that was used.
Old Nov 25, 2003 | 08:15 PM
Duffdog's Avatar
he he he....
you should ask pioneer why they refuse to supply a separate power ant. lead and amp lead. Only a few brands do this, one is pioneer, another is sony--i believe eclipse does that too. not all radio's are designed the same, but putting a switch that removes 12v from the ant. lead will make it go down.
T
Old Nov 25, 2003 | 08:50 PM
DuB's Avatar
DuB
my roommate is a die hard pioneer fan and all the headunits he's owned kept the antenna up
My Sony drops the antenna when I'm not playing the radio though...
If you want to install a switch that drops the antenna when the cd player is on, like duffdog said, you can just install a switch inline with the antenna lead. If, for some reason, you'd want the antenna up when the headunit is not on, just use any 12+ source and a switch.
Old Nov 25, 2003 | 09:00 PM
fourunnabilly's Avatar
Guest
This may seem way too simple, but you can buy generic internal antennaes to fit any deck, then all you have to do is either cut the power wire to the antenae, or just pop it out and disconnect it and put it back in...i have done both in the past. I'd help with more detail, but i gotta run. Good Luck.
Billy
Old Nov 26, 2003 | 03:48 AM
ugadawg95's Avatar
Originally posted by smr4runner
Hmmm?
I used the schosche (sp) harness and wired the blue antenna lead from the aftermarket harness to the blue antenna wire from the alpine pigtail. Alpine has a seperate lead for the antenna and also for the remote turn on to the amp, which is blue white. If you need me to take some pics let me know.
Old Nov 27, 2003 | 02:05 AM
smr4runner's Avatar
Hey saintsteve,
If you have a pics of it, it would help immensely.
Thanks Dude
Old Nov 27, 2003 | 07:24 AM
j-dub's Avatar
Originally posted by <96 Runner>
DEH350P "Premier"
Is that the same as this:
http://www.sounddomain.com/sku/PIODEHP3500
How do you like it, my sony is taking a crap and I need to replace it soon.
Thanks
Jeremy
Old Nov 27, 2003 | 04:46 PM
Thanks
Jeremy
I love it! the sound quality is amazing for a deck in this price range. I would highly recommend getting this deck via Costco.com for $149. No shop could even come close. Plus, they have an unconditional satisfaction garantee. If you dont like it or it craps out, just take it in to any Costco for a full refund.
Cant beat that!
jasonty
41
Dec 23, 2018 01:00 PM
theking11863
Mar 19, 2016 09:36 PM
shisha1999
Sep 20, 2015 11:35 AM
Peevedkitten
11
Aug 31, 2015 06:57 PM
corey519
Aug 12, 2015 11:12 AM
