Steering stop question.....
Old Aug 14, 2002 | 06:51 PM
rpeAMP's Avatar
I have a 1992 4Runner and it has the infamous problem of making a noise when I turn. However, my situation tends to differ from those turned up when I search for info on this. First of all, the sound for me is more like a "popping" noise. Does this mean anything? Also, this popping noise occurs sometimes even if the wheel is not all the way locked, but close to it.
Am I looking at a different problem here or the same thing?
Old Aug 14, 2002 | 06:55 PM
Adam F's Avatar
mine made the same noise i think. sqeak, pop
Old Aug 14, 2002 | 06:57 PM
Corey's Avatar
Co-Founder/Administrator
It sounds like it to me. My '90 truck use to do that a lot, and of course I did not know what it was back then.
After I got the Runner in '98, it's never done it once.
I bet Toyota puts lube on it everytime it goes in for the oil change.
Try putting some heavy grease on the end stops and see if that clears it up.
You can see the black cap on mine just to the right of the tire near the bottom.
You can see where it hits the lower A arm too. Just dab some grease on both spots and see if that fixes the noise or not.
Old Aug 14, 2002 | 06:59 PM
Shane's Avatar
Mine pop more than the squeek.
The only other thing is if your ball joints are shot or dry... try lubing them if you haven't recently.
Also remember that there are 4 stops, not just two so make sure you put some grease on all of them. If they're not adjusted properly one side might hit before the other and cause the squeek before it feels like you're at full lock.
Old Aug 14, 2002 | 07:07 PM
rpeAMP's Avatar
Thanks for the replies! I'm glad to know that I don't have a bigger problem than that. I'll go get some grease and lube them up and if that doesn't work, I'll take it into the dealer.
Old Aug 14, 2002 | 09:25 PM
CLin9383's Avatar
on my accord, it was a bad cv boot...maybe that's it?? i could be wrong...just a stab at it
Old Aug 15, 2002 | 08:21 AM
ropre's Avatar
Does it make this popping/grinding noise when not turning hard all the way? If so is it just on one side of the front end or on both, or can you even tell?
If it hapens when you turn normally (not fully cranked) mabey increased as you turn and go over rougher road. Anyways if this is happening more than just when you are fully cranked it could not be your stops.
I have a friend w/a '90 runner and she has nutorius troubles with her stering knuckles. The seals interferance surface is all screwed up and they do not hold grease. They then dry out and start making terrible noises.
Anyways just an Idea
Good Luck
Old Aug 15, 2002 | 02:22 PM
rpeAMP's Avatar
Ok, well I took a look and here's what I found:
So it looks like I found the problem! Look how worn down the stops are! Is this a problem? Do I need to do more than just grease them?
Old Aug 15, 2002 | 02:31 PM
Corey's Avatar
From looking at your photo, it looks like you were underneath and shot the drivers side?
All you need to do is dab grease on that, and the plastic stop by your tire like in my photo.
Your cap may not be on though, and that is OK, Just dab grease on that part too.
Corey
Old Aug 15, 2002 | 03:03 PM
rpeAMP's Avatar
Yes, sorry...I didn't even look at the picture between when I shot it and when I posted it. Where can I get those plastic caps?
Old Aug 15, 2002 | 03:12 PM
Corey's Avatar
You can get them at the dealer for $5 each I think, but it's a rip off.
You don't need them really. Most folk's just smear the grease where the caps use to be, as the caps will wear down.
I'm not even sure if I have the caps. I'll have to look later as that photo I took was from a few years ago.
Corey
Old Aug 15, 2002 | 04:37 PM
Shane's Avatar
That gouge you're seeing in the steering stop pad things is normal, I've yet to see a rig without that on the stops.
stoneboy91
Apr 5, 2016 05:17 PM
delmert
Sep 30, 2015 04:34 PM
Up&Down
Aug 5, 2015 06:20 AM
JHalcyonM
Aug 4, 2015 01:19 PM
bobpat
Aug 1, 2015 09:25 PM
