squeaky sound from startup
Old Jan 28, 2006 | 02:52 PM
BigJohn's Avatar
when i start my truck i get a squeaky sound for about 10 seconds i think it is the fan belt and should i replace it is it easy to do yourself
Old Jan 28, 2006 | 03:13 PM
MTL_4runner's Avatar
Look at the belt and see if there is any cracking on the ribs, if there is, replace it. If not, just it is likely the belts just need to be tightened. If you have not changed the belts in quite a while, it may still be worth changing the belt.
Old Jan 28, 2006 | 03:24 PM
lee's Avatar
lee
definitely a belt.
you can use belt dressing to quiet it till you change it
Old Jan 30, 2006 | 02:51 PM
surf4runner's Avatar
is it a squeek or a squeal? my pulleys squeek for a few seconds to a couple of minutes (when cold). belts tend to be more of a squeal
Ditch Doc
Oct 27, 2015 03:20 PM
voiddweller
Sep 28, 2015 11:21 PM
toyotasaurus
Sep 24, 2015 03:30 PM
langry345
Sep 14, 2015 03:36 PM
northwalker
Sep 3, 2015 12:21 PM
