Sprayed carb cleaner in my 5VZ-FE throttle body
Old Apr 20, 2005 | 08:59 PM
Auratus's Avatar
I cleaned my throttle body tonight and absent mindedly grabbed a can of carb cleaner not recommended for use with fuel injected engines (Gumout carb + choke cleaner). Did I make a catastrophic error? What kind of fallout if any can I expect from this?
Thanks
Old Apr 20, 2005 | 09:10 PM
3.4v6's Avatar
your fine ... thats what i use
no worries
Old Apr 20, 2005 | 09:14 PM
blink's Avatar
you should be fine like 3.4 said. I wouldnt get into the habit of it just because it will burn up your cats.
Old Apr 20, 2005 | 09:37 PM
Auratus's Avatar
Thanks for the reassurance. I read the lable on the can after the fact and started sweating bullets. The truck does seem to have a good bit more juice after the TB cleaning, so I guess it did its job.
Old Apr 20, 2005 | 09:48 PM
blink's Avatar
sounds like it...... you should clean off your maf with a little alcohol as well... that always helps to pep up the engine
Blamalam
Mar 12, 2022 07:34 AM
montanatruck
Feb 26, 2017 07:07 AM
mussy01
Dec 13, 2016 08:20 PM
jetpilot
Aug 15, 2015 06:48 AM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
