Speedometer readings?
Old Oct 8, 2007 | 07:15 PM
Sloan's Avatar
http://www.miata.net/garage/tirecalc.html
Old Oct 8, 2007 | 07:57 PM
LJ_24's Avatar
Originally Posted by unitofstuff
From 265/70/16's to 265/75/16's is a 3.4% speed difference. When the speedometer says 60mph, you're going 62. Also consider that if you're going to more aggressive tires from street/bald tires, you'll probably gain a little more height than just the sizes say.
--can anyone confirm this
--btw, that is the most detailed explanation i ever got on yotatech!
Old Oct 8, 2007 | 08:40 PM
Texas_Ace's Avatar
Yes, i can confirm that. It was a nice explanation, i should have remembered that site. A more aggressive trie can have larger tread and thus a slightly larger overall size which can mean an extra little bit on the speedo.
Old Oct 9, 2007 | 03:27 AM
xsvtoyz's Avatar
if you went from 265/70/16 to 265/75/16 for every 100 miles on the odometer you actually have travelled 102-104 miles so your speedometer is off by maybe 1-2 mph not enough to even consider a recalibration save your money
so if you are traveling at 70 speedometer wise your are actually traveling at 71 or 72 I did the same tire size change and they had a radar display on my way to work I went by it for months before and after the change and it was so close on every pass I finally quit worrying about it
mund1011
Aug 16, 2015 07:10 AM
teknovls
Aug 9, 2015 12:37 AM
Dennisx2
Aug 4, 2015 01:26 PM
altydog
Jul 28, 2015 10:20 AM
wilbertd
Jul 6, 2015 07:39 AM
