Speedometer change w/bigger tires?
Old May 25, 2004 | 02:07 PM
YorkieMomma's Avatar
Hey guys,
I was wondering if anyone knew if you lost or gained a few miles per hour by changing the size of your tires? I had stock runner tires on then I got the new bigger tires and was just wondering if that had any kind of impact on the miles per hour you go? Is the speedometer connected (somehow) to the front tire or is it connected to the tranny? Anyone know? Just a curious question. Thanks for any info. in advance!!
YM
Old May 25, 2004 | 02:31 PM
Darx's Avatar
Yes, larger tires will read slower on the speedometer. Use that site in Mark's post, I used the same one, to get the new speed. Remember also it will change your odometer. When I got a GPS unit I no longer have to worry as much as the speed is pretty accurate and I use its trip meter for guesstimating my oil change intervals.
Old May 25, 2004 | 02:33 PM
PoBoy's Avatar
there are a couple devices that will fix the spedo problem...superlift makes one and dakota? is another.
Old May 25, 2004 | 03:02 PM
Fink's Avatar
What would a 31x10.50R15 be? 265/75R15?
What about a 33x12.50R15?
Fink
Old May 25, 2004 | 03:07 PM
Darx's Avatar
Fink
I found this one which works backwards from what you're asking but you can get it figured out.
http://s87708598.onlinehome.us/sy/tirecalc.html
Flying91
45
Apr 11, 2024 04:39 PM
djpg2000
Nov 11, 2020 04:56 AM
TammyMarie
Jul 15, 2015 11:14 AM
wilbertd
Jul 6, 2015 07:39 AM
