Specs on 3rd members
Old May 17, 2004 | 07:56 PM
I have an 82 4X4. I have a 3rd out an 87 4X4 (rear) Is there a ratio difference or will it drop right in. Speaking of specs, What is my best resource for technical info, compatibility questions ect.?????? I am humbled by your wisdom
Old May 18, 2004 | 01:11 AM
superjoe83's Avatar
it will bolt in, but the ratio may be the same or it might not, you wil have to count the pinion and ring teeth to find out if there the same ratio
Old May 18, 2004 | 07:46 AM
kyle_22r's Avatar
all '82 4x4s had 4.10 gears stock. i'm pretty sure '87 did as well...always be a good idea to count teeth first though
Old May 18, 2004 | 10:16 AM
DoubleA's Avatar
'87 with automatic transmission had 4.30 gears stock.
Old May 19, 2004 | 07:18 PM
It's a 5-speed. So you think it's the same. Great! thanx.
Old May 20, 2004 | 07:43 PM
AKennedy87's Avatar
Yep, my 87 4Runner 22RE 5-Speed has 4.10 gears so you should be solid.
jerusry
Oct 19, 2015 05:28 PM
boogiewoogie
Aug 17, 2015 12:47 PM
cr@ves4wheelin
3.4 Swaps
Aug 17, 2015 07:47 AM
