Which spark plugs do i buy?
Old Nov 7, 2006 | 12:06 PM
Elton's Avatar
well the fuel smell makes me think the cat is going bad
Old Nov 7, 2006 | 12:12 PM
chadbobb's Avatar
Read the thread i posted for that ^^
I can get 7 spark plugs (incase one is bad or something) new wires, and a rear middle seat belt form autopartswarehouse.com for $85.12
Is that a decent price??
SW5605
Product: Standard Ignition Wire Set
Vehicle: 1996 - 1998 Toyota 4Runner
Notes: Ignition Wire Set, Original Equipment Replacement Spark Plug Wire Set, Tailor Fit, Restores Efficency and Performance
Shipping: This item is shipped Ground, 2nd Day, and Overnight.
Update
Remove $47.95 $47.95
F1000-56650
Product: Denso (OEM) Spark Plug K16TR11 ND
Vehicle: 1996 Toyota 4Runner V6 4WD
Notes: Toyota 1996 Denso (OEM)
Update
Remove $1.89 $13.23
US-SBELT-2
Product: Replacement Seat Belt
Vehicle: 1996 - 2000 Toyota 4Runner
Notes: SEAT BELT -- . 2-point Seat Belt type, 1 pc (RH=LH), Ground Shipping Only
Shipping: This item is shipped Ground Only.
Old Nov 7, 2006 | 12:16 PM
Elton's Avatar
go with the ngk's i posted and these Plugs
Old Nov 7, 2006 | 01:08 PM
mpavolka's Avatar
Get the NGKs! They are the best
Old Nov 7, 2006 | 02:47 PM
  #25
04 Rocko Taco's Avatar
this makes 25 posts, and all it needed to say is OEM.
Old Nov 7, 2006 | 04:23 PM
  #26
chadbobb's Avatar
Yeah, those are the same ones i think i posted. I posted K16TR11 ND and you posted from the other site K16TR11. So its the same thing probably.
What do you mean by "go with the ngk's i posted"
Do you mean the wires? Cause you posted denso plugs
Old Nov 7, 2006 | 04:27 PM
  #27
Elton's Avatar
ya the wires
Old Nov 8, 2006 | 05:10 PM
  #28
chadbobb's Avatar
Ok. Do the wires come with boots? How many boots should it come with? The coils will have their own right? So i should only need the 3 with the wire set?
Old Nov 8, 2006 | 05:27 PM
  #29
Elton's Avatar
wire set comes with 3 wires all you need to do is reuse the clips from the old ones
Old Nov 8, 2006 | 05:51 PM
  #30
Machine's Avatar
I just got some NGK Iridium's and they are great!
Old Nov 8, 2006 | 06:46 PM
  #31
chadbobb's Avatar
alright. I just placed a $90 order. Got 7 new spark plugs, wire set, air filter, and rear middle seat belt
Old Jan 19, 2007 | 12:01 PM
  #32
soldsep's Avatar
Hey, Did this ever fix your gas smell issue?
Old Jan 19, 2007 | 12:31 PM
  #33
CyMoN's Avatar
http://catalog.autohausaz.com/autoha...t=Spark%20Plug
Old Jan 19, 2007 | 02:30 PM
  #34
chadbobb's Avatar
It is hard to tell right now, as during this time of year it is impossible for me to open any of my windows....
I am going to have to wait until spring.
I do notice though that my gas milage has wondered down to 14.9ish mpg from the original 17.1 i got last may. I hope it is just because of cold air and bad winter gas.... So this spring i will have to recheck everything
Old Jan 19, 2007 | 02:50 PM
  #35
mehret's Avatar
Get a set of Bosch Platinum 2 plugs. Nuff said.
Old Jan 19, 2007 | 03:30 PM
  #36
keithguts's Avatar
EASY, Just go to a local dealership, and they will give you what the rig calls for. It dosn't get any easyer then that.
Old Jan 19, 2007 | 03:53 PM
  #37
chadbobb's Avatar
ok... thanks... got them.... this thread is months old....
The only thing unsolved is the gas thing.... as i said above
Old Jan 19, 2007 | 03:59 PM
  #38
keithguts's Avatar
So tell us, what did you wind up buying?????
Old Jan 20, 2007 | 08:46 AM
  #39
vrrodri's Avatar
I got a set of blue NGK wires for my 99 Taco and hope this will cure the misfire...plugs already changed as well as the PCV and cleaned the MAFs and airfilter...and replaced all vacuum lines with silicone hose.
Old Jan 20, 2007 | 09:02 AM
  #40
chadbobb's Avatar
just some cheap denso plugs and an NGK wire set
