Sloppy automatic shifter
Old May 28, 2016 | 02:05 PM
kbrashears's Avatar
I replaced my bushings today. Best fix to my 98 Tacoma yet. There are four to replace. Not two. Two are accessible from the top, but you have to remove the assembly to get to the two on the bottom.
Old Jul 27, 2016 | 01:46 PM
madmallard87's Avatar
I have same problem with my 94 4runner. Is the part number in the diagram above the same for my 4runner? The slop in mine is terrible!
Last edited by madmallard87; Jul 27, 2016 at 01:52 PM. Reason: Adding information to post.
Old Aug 21, 2016 | 05:21 PM
thelasteaglescout's Avatar
Are all (4) bushing part numbers the same? The diagram everyone is sharing seems to only show two of part number: 33501G. Thanks.
Old Aug 21, 2016 | 05:24 PM
Sorry, one more question. I can see how this effort will resolve my issues with my key getting stuck in the ignition, but do you think this fix will also help with my key not turning in the ignition or is that more likely a worn out ignition switch.
Old Jan 13, 2019 | 11:12 AM
  #25
tns1's Avatar
I recently replaced the automatic shifter bushings for my '98 ltd 4WD at 300k. It requires 4 bushings #90385-11003. My cost was $14 shipped from McGeorge Toyota. They are soft blue plastic as shown above, and two of mine had completely disintegrated. It took about an hour, but I removed the shifter from the truck before tearing it down. I put a bit of grease in the new ones. Shifting is like new, and well worth the effort.
punks_is_4x4
Feb 26, 2016 04:29 PM
Truckwithoutaname
Oct 3, 2015 03:41 PM
Flightguy
Oct 2, 2015 05:34 PM
bradahman
Oct 1, 2015 09:24 AM
tshort48
Sep 27, 2015 01:04 PM
