skid plate woahs.
Old Aug 11, 2003 | 01:31 PM
amorphous's Avatar
skid plate woahs.
hey guys,
i took off my skip plate on saturday when I switch the 4r over to mobil 1 and I have a stripped insert bolt (not my fault!- it the farest one back on the front skip plate piece, where the rear and front connect).....I managed to jury rig it back up with a skinny nut/bolt combo - but is there anyway I can fix the threaded insert?
thanks,
aaron
Old Aug 11, 2003 | 02:38 PM
boss hog's Avatar
go to sears and buy a small tap and die set, that includes a 8mm tap. tap out ruin skid plate nut and rethead 8mm bolts or buy new 8mmx1.25 bolt from pep boys.:pig:
Old Aug 11, 2003 | 02:51 PM
Bob_98SR5's Avatar
Tapping is fun!
Make sure you use plenty of tapping oil. Make very small (under 1/2 turn) turns until you feel the thread "set". Add more oil and then turn again.
If there is such a thing as spray tapping oil, you might need it given the fact that the thread is inverted. Otherwise, try a syringe.
Bob
Old Aug 11, 2003 | 03:01 PM
PoBoy's Avatar
Give up and just SAS. No need for a skid plate then
Old Aug 11, 2003 | 03:33 PM
Sparman's Avatar
Also, if you haven't already, you should rplace the factoy 8mm self-tapping bolts with non-self-tapping 8mm x 1.25 bolts.
I swapped mine very early on and I haven't yet stripped any of the factory threads -
and that's with a rockstomper skid that comes off every 3k for oil changes.
Old Aug 12, 2003 | 05:28 AM
amorphous's Avatar
thanks for the advice....
had a feeling that it was either deal with the 'rigged' set up that I have or tap away.
thanks for the advice guys!
aaron
justdifferentials
Just Differentials
Jun 13, 2022 07:40 PM
kawazx636
Oct 6, 2021 03:03 PM
kawazx636
Sep 29, 2015 08:22 AM
Aaronmarston
Sep 22, 2015 09:39 PM
AlexJet
Sep 14, 2015 09:00 AM
