Should i Trust vin Decode gear ratio>?
Old Feb 18, 2004 | 03:13 PM
88FJ62-Cruiser's Avatar
according to brian894x4.com my gear ratio is 4.10. has anyone run across a case were there ratio was different? i am going to be buying a 4.10 e-locker and wanted to make sure it matched the front diff. thanks
Old Feb 18, 2004 | 07:45 PM
Mojo_Risin's Avatar
I wouldn't trust it that much but it's probably correct. Call the dealer - they can verify it for you - although it took me 3 different dealers to find one willing to take the time. You can also jack up 1 rear tire, mark the tire and the driveshaft - turn the tire 2 full revolitions at the same time count the revoltuions of the drive shaft - just a hair past 4 revs of the driveshaft = 4.10 a little more than 4 1/2 turns is probably 4.30 (which most autos have - not mine unfortunately)
Old Feb 18, 2004 | 08:01 PM
amusement's Avatar
Saletel I did the same thing last weekend. Went to Brian's web page to look up G254. His site indiated it was for a 4.56. I swear my detriot locker and gears are 4.10 back there. But, also remember giving the VIN to parts place so maybe they got it right. It would be really stupid / wierd to have 4.10 in the back and 4.56 in the front. I haven't had a problem so I assume all is well. But, having 4.56 gears make sense for my 3vze. Cause at 70 mph the engine is about 3,000 rpm with 31x10.5 15 inch rims.
Old Feb 19, 2004 | 06:51 AM
runnerboy97's Avatar
You got it. Actually, most autos came with 4.10, it was the locked 4runners you could get in 4.30
Old Feb 19, 2004 | 07:52 AM
justinh's Avatar
some limiteds with the auto had 4.30 without the rear locker.
Old Feb 19, 2004 | 09:39 AM
my key word was most. I knew some had the lower gears, i think it was 3.90. thanks for clearing that up though.
jasonty
41
Dec 23, 2018 01:00 PM
tobylab
Dec 3, 2015 08:41 PM
pyramid
Jul 29, 2015 06:53 AM
justdifferentials
Just Differentials
Jul 22, 2015 08:26 PM
