Satoshi done!, different mesh, pics, etc
looks good too, besides the zip-ties, I wanted a material that wasn't standard expanded metal, was pre-colored... That way no maintenance, and could actually pass as semi-stock at a first glance... another note, you just completely installed that mesh over your existing grille right?
#26
The "Satoshi Grill" is named after Satoshi Miura a gentleman in Japan who was the first guy to do this mod and post it on the web for all to see and emmulate.
There are several variations on the original that different members here have done, though they all adhere to the original concept to a greater or lesser extent.
If you do a search here under "Satoshi Grill" you will find many posts/threads on it easily one of the most popular and talked about mods out there.
Here's a link to one of the original North American right-ups on this mod http://web.archive.org/web/*sr_41nr_...4runners.org/*
I have no idea how long it will be good for.
See 3 entries under "Satoshi"
#27
very nice work. Thanks for including where to find the mesh type materials.
I really admire you guys willing to cut and experiment for the benefit of all of us who pester you with questions. I could easily destroy 3 or 4 grills trying to learn from my own mistakes.
Nice photos and thanks for posting those to help with the visualizations.
#31
Yeah, I didn't have the right grille either until I bought a used one from a member here.... with the 02 grille, you could surely find someone to trade, there are a lot of 96-98'ers that want the newer stuff
#32
there are so many versions of this that others have done, that (1) it makes it really easy to learn from mistakes and (2) it shows a ton of options if you want to copy someone else's method exactly
#37
here is a couple of ours. I don't like the see through effect of the thin mesh so I went with a heavy flattened aluminum. I didn't like screws sticking in the grill either so I went the zip tie route. The mesh was bent around the frame so so the zip ties really don't have a big job to do. I think this will hold up good for a long time. I wanted the OEM look.
