RR diff
Old Oct 9, 2003 | 01:11 PM
Kolo's Avatar
RR diff
98 4Runner Ltd. 135,000km
When I push the RR Diff Lock button the light just keep flashing. I tried L4, Neutral same result just keep flashing. Any thing I should check b4 send it to the dealer ?
Old Oct 9, 2003 | 01:32 PM
Billf6531
Guest
Posts: n/a
In 4Lo, drive ahead at idle speed while turning throught an S shape. It'll lock up when the splines engage.
Old Oct 9, 2003 | 02:14 PM
Kolo's Avatar
My concern is in case I got stuck and the rear wheels are spinning even in L4. If I cannot get the RR Diff Lock engage at that moment I will be in trouble. I wonder is this a common problem for 4Runner.
Old Oct 9, 2003 | 02:58 PM
Billf6531
Guest
Posts: n/a
Both will not be spinning at the same time. A touch of gas will cause one to spin, and line up with the one with traction, or different amount of slip, and the locker will engage. Stop worrying about it. Take it out and prove it for yourself.
Old Oct 9, 2003 | 03:44 PM
Darren's Avatar
You should have your locker already engaged before you get in a potentially stuck situation.
Old Oct 9, 2003 | 04:00 PM
Billf6531
Guest
Posts: n/a
That's very true, and good advice.
Old Oct 9, 2003 | 05:06 PM
rpeAMP's Avatar
Does it engage now?
live4soccer7
May 11, 2016 06:52 PM
Badlander
Oct 10, 2015 08:05 PM
Odin
Sep 26, 2015 06:56 PM
toyotasaurus
Sep 24, 2015 03:30 PM
zz_denis
Sep 6, 2015 03:43 PM
