replaced thermostat - leaky bolt
Old Feb 27, 2011 | 04:33 PM
rworegon's Avatar
Originally Posted by TheDurk
For the record, the FSM (page C-12, V. II of my '99 edition) says jiggle valve down. I just do what Toyota suggests. I doubt it makes much difference.
The '95 FSM for the 5VZ-FE also says Jiggle Valve down on page EG-194, Thermostat Installation 1(b). Someday I may flip mine from down to up and see if SGII shows a difference in temps. I doubt it will.
Old Feb 28, 2011 | 11:00 AM
diesel power's Avatar
not sure about the tensioner. i'd have to look at my stack of receipts from the previous owner. fan clutch appears good as it does the typical roaring for a bit after starting the motor.
Originally Posted by J2F42C
Do you know if the timing belt tensioner was replaced at the same time?
I'd start to say to check the fan clutch, but since you see these temps all the time, not just idling in traffic, I'm inclined to believe it is not the clutch.
Sep 4, 2015 09:27 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
87blyota
Jul 10, 2015 04:31 AM
Snort
Jul 9, 2015 03:58 PM
