Removing Oil Pan
Old Dec 21, 2007 | 02:34 PM
BajaRunner's Avatar
Removing Oil Pan
I've searched. I know what to take out to get to the pan. I've taken out all the 20 bolts, etc...
The damn thing won't budge. I've hit it, tried to pry it... How the HECK do you get it OFF the engine block. I know its got a sealant on it. I just can't get it loose.
Are there any tricks?
All the things I've read don't even mention the fact that its sealed on there.
Old Dec 21, 2007 | 02:39 PM
icerunner's Avatar
You might want to try heating up the seal with a blow dryer and that may help things expand some and come loose a little bit easier. Also, if you are going to hit the oil pan, wack it with a heavy rubber mallet. Yet try to be carefull not to hit it too hard to bend or warp the pan.
Old Dec 21, 2007 | 02:41 PM
INFINITY's Avatar
i have had a hell of a time removing oil pans in the past. the cork gasket does not help at all. but i would say get a thinner putty knife and if you can tap it with a hammer on the gasket and work your way around the pan and see if that breaks it loose.
good luck
Old Dec 21, 2007 | 02:53 PM
BajaRunner's Avatar
Thanks guys!!
I just wanted to make sure that this is indeed a weird thing, and I wasn't doing something obviously wrong. I couldn't figure out why the thing is stuck on there so tight!!
Old Dec 21, 2007 | 02:58 PM
4runnerchevy's Avatar
Banned fruitloop
Warm it up
Warm it up, and it will come off easy.
Old Dec 21, 2007 | 03:01 PM
icerunner's Avatar
good luck
THis is good advice yet careful to not "score" the pan's sealing edge (motor side or pan side) as that seal is exact and it will leak if your not somewhat carefull.
Thinking back: I just remember how many times i hear of trans pans leaking (after dropping the pan). Usually, the seal was not carefully installed and/or the prep surface was not perfectly clean....It would be my luck that I would damage the pan...and have a leak....
just my 1 cent
Old Dec 21, 2007 | 04:59 PM
BajaRunner's Avatar
Well, I got it off in like 1 minute. I just took a metal paint scraper/spackle spreader to the front of it, and just worked my way around. Came off.
Now its too late to put it back on. So I cleaned it really nicely, and tomorrow morning will go back on.
BTW - I just took off the oil-pickup rather than drop the diff. It worked fine. Now the thing is that I will need to put the sealant on underneath the truck... I don't think it will be a problem though.
Sep 4, 2015 09:27 AM
thefishguy77
Jul 30, 2015 10:59 AM
irritech
Jul 27, 2015 05:15 PM
ryerye13
Jul 14, 2015 08:27 AM
HRDC0R19
Jul 5, 2015 06:43 PM
