Remote Mount Turbos
Originally Posted by oly884
That did seem a little bit low for the TRD supercharger, but what's the average hp loss through the drivetrain on our trucks?
Originally Posted by CynicX
well trdusa.com says they got 264 hp or something with the TRD ECU, which i think would be more actuate then 203...
That is quite a big difference, but was that 264 at the crank or at the wheels?
another thing to remember is all dynos are different....if you take a vehicle on a mustang dyno it will be lower then a other dyno machines....
finally saw one
i saw one of these on a 6.0l chevy 2500 hd at the track tonight. he was running that beast in the 14's. he said it was the prototype so he got it free. he also said that he drove 5 hours in the rain with it and had no problems with the location of the turbo yet all his problems are with the computer. he showed a dyno sheet of 330 rwhp.
#25
#26
this isnt a bad idea if you want something simple....but a turbo under the hood will have less lag and bigger power they say the HP goes from 140-220...which is pretty good for a simple install....80 HP
take the scooby 2.5 165 HP and put the sti turbo on it and you'll be running around 300 HP (with other upgrades of course, injectors, intercooler)....135 HP gain...
put a bigger turbo on a vehicle with the turbo up front you'll get more lag but bigger power....unlike the sts which is to far downstream to put anything bigger on....
in the video on the sts page it says the turbo condenses cool air and sends this cool air back to the engine...which is pretty odd considering when you condense air its gonna get really hot, this is what the intercooler on a car with a normal turbo is cooling, this hot condensed air...that makes the page kinda shadey too me....
I think I'd stick with the TRD supercharger.....
and dont get me wrong I'm not knockin this product, I just dont think its very useful for offroading and its webpage isnt very actuate....
The straight pipe which sends the gases back to the engine is coated with HPC, and that acts as the intercooler.
#27
The whole page still seems kinda shady to me.
As far as driveline losses, 15% is a good rule of thumb. So 345HP at the crank would be ~293 at the wheels. Doesn't seem like much of an improvement...
#28
According to that, with the trd s/c 3.4L's should be getting around 225 rwhp. Not bad. Car companies should advertise with whp not crank hp. That way you know what you're getting. I still think that the remote turbo might not be too bad. I mainly do street driving, so this application may not be good for everyone.
#29
I can see where the super charger would help in certain situations. Off roading would be a main one. As for me, this kit seems to fit my needs better. I also don't want to have to deal with all the problems involved with the super charger.
#30
That is NOT a sufficient intercooler.
This is a POORLY designed system. WOW.
And as for wheeling w/ a turbo... I know plenty of guys w/ rigs (including my roommate's) that run the 7MGTE motor out of a Supra... that's right... a TURBO-charged rig. They do fine, AND spool around 2k rpm.
#31
humm this is some funny stuff thanks for the links i will pass it on, this would never go on my off road truck because when u crawl u are in the low low rpms no extra power till 4k in my mind this product is great for all thjose way over lifted show queens we see running up and down the roads that never see dirt but cant ever pass the gas pump.
#32
Originally Posted by WolfpackTLC
Please tell me you're joking...
My offroading ranges from 1k-3k so spooling at 2k wouldnt fit my application
#33
Couldn't you just add it to a S/C'd engine? I know some busses are S/C'd and T/C'd. They need one (S/C or T/C) just to make them run or something like that. I think it's the turbo. Hence the turbo diesel trucks and cars. The way that diesel "burns" has something to do with it.
Enlighten me on this.
#34
you could always up the psi with teh s/c but you'd run into pinging problems.....
#35
oh well I was wrong then, I personally didnt like wheeling the turbo but I guess its user preference. I cant imagine dishing out the money for a 7MGTE for an offroad rig when you could get something more reliable and powerful (torquey since thats where you need it when offroading) that isnt as dangerous but to each there own. Do they have blow off valves too?
My offroading ranges from 1k-3k so spooling at 2k wouldnt fit my applicationThe 7mgte IS stronger @ 2k than the 3.0, so that's nice too....
#36
hahah offroading with a turbo charged truck...that would be interesting.....picture this : You're climbing a steep grade and have no power because the turbo isnt spooled yet but it is interfering with the natural exhaust flow so you have less power in the low rpm range then before you got it....so your climbing and climbing and giving it more gas...nice and easy, nice and easy...then BAM here comes your additional 50 horsepower like a kick in the ass.....now your spinning wheels and in a crazy position...no thanks
plus think about it 90% of 4wheel low offroading is in the low rpm range....a turbo is useless in the low rpm range....if a turbo was a good idea offroad people would actually use them.....
I drove a 4 banger turbo charged jeep offroad and it was very scarey even on a moderate trail. I didnt feel safe enough to try it on the rocks because I was scared of the rush of power while being in a hairy situation. Even with the owner driving it was scarey and I think he was pretty scared too.
No, this would not be a good set-up for extreme rock crawling, but would be very nice for what we can do in even the most modified Runner.
I'd say for those interested look into a Garrett T3 or maybe even the ever so popular Toyota CT26 used in the Celica, MR2 and Supra. You can pick up either of these turbos for cheap on ebay and rebuild them. I've seen CT26 turbos that use Garrett ball bearing centers.....this makes them pretty lethal.
As for the reasoning behind the remote turbos........makes no sense. Use a turbo blanket and exhaust wrap.
#37
#38
#39
#40
Ok, now why remote mounting works!!!!
I know this guy, he is just down the street from me. In fact, I was just at his shop yesterday, and he gives me a great deal on 180 degree mandrel bends.
Anyway, a turbo and s/c are just forcing air into the engine. A turbo uses exhaust gasses and a s/c uses a belt. This will increase the pressure in your intake by a certain pressure.
Lets say we have a N/A car or truck. Most N/A's run around with 10:1 or 10.5:1 compression. With that type of compression about the max you can go on boost is 7 psi. Lets say you have a turbo mounted right at the engine and it is set to set psi. It will build boost until it hits 7psi. Now, take the rear mounted turbo. It is also set at 7psi. It will build boost intil you hit 7psi.
7psi, is 7psi. Now, you could have really hot 7psi, or really cool 7psi. Usually most cars that are turbocharged that only go to 7psi don't have intercoolers. The air doesn't get that hot anyway. By increasing the pipe length between the turbo and the engine, you can effectivly cool the air than if the turbo was at the engine.
Turbo lag
As long as your compressor and turbine are matched for your application, you can reduce turbo lag. Rear mounted turbos will probably use a slightly smaller turbine housing than a engine mount. You have just as much air at the front of the engine than you do at the rear. Yes it is slightly cooler, which means that the velocity is a little less, but when you are only talking about 7psi, that is isn't a problem for rear mounted turbos.
This system works, and it is bolt on. Easier to install than a S/C.
As for an off-road truck? Heck no would I run something like this. Turbo is down too low, but that would be the only reason why.
Turbo lag
