relay clicks when I let off the gas
Old Sep 17, 2004 | 09:48 PM
SlimJim248@earthlink's Avatar
I have an 85 runner, 22re and when I rev it or am driving and let off the gas a relay clicks under the dash, sounds like the passenger side. It just starting happening tonight, so I haven't checked exactly where it is coming from, but I didn't know if anyone has had this problem before. Any help would be appreciated, Thanks.
Old Sep 18, 2004 | 06:53 AM
SoCal4Running's Avatar
I had the same relay "click" happen when my 22re lost a piston ring. It would only click when coasting or idle. It is behind the passenger kick panel.
Never did find out what it was because I knew the motor needed major work, and after rebuilding and cleaning everything it has not come back.
I would check all vacum hoses under the hood and also all the electrical plugs to make sure there tight. Have you tried to pull any codes?
Old Sep 18, 2004 | 08:51 PM
I ran the codes, but it blinks only once, saying it is ok, I think I am gonna have to take it apart and find exactly where it is coming from, Just got back from wheelin today, still clicks, but didn't affect the performance. Thanks
Old Sep 18, 2004 | 09:22 PM
cabbage's Avatar
I believe its your AC, mine does the same, only when the AC is on. The compressor doesnt kick in until the engine reaches a certain rpm.
Old Oct 12, 2004 | 07:27 PM
Well after I blew my head gasket last week I decided it was time to rebuild it because it is pretty tired. my #1 piston had about 1/4 of the compression ring just like SoCal4Running said had happened to him. Thanks for the help.
Old Oct 12, 2004 | 07:31 PM
cabbage's Avatar
Exclamation
I hope the clicking we're talking about is different!!! Glad you found your problem..
Old Oct 12, 2004 | 08:05 PM
Our problem sounds different, my click happened with the a/c on or off, I wouldn't sweat it. Thanks for the help
SubiKing
Aug 21, 2021 03:57 AM
mussy01
Dec 13, 2016 08:20 PM
mluz013
Aug 2, 2015 05:00 AM
Sandman
Jul 14, 2015 12:36 PM
colinmil
Jul 6, 2015 04:03 PM
