Rebuilding aisin hubs
Old Jan 17, 2003 | 01:22 PM
Adam F's Avatar
I found the springs. Thanks guys!
Old Jun 16, 2006 | 05:14 AM
cootees's Avatar
Originally Posted by Cebby
On mine, the big spring inside the hub (#8 in Adam's pic) is a little corroded. I managed to strip most of the corrosion, but the spring isn't a consistent thickness where the corrosion was (it is thinner there, metal eaten away by ?). There is no fear of it breaking cause it isn't THAT bad, but should I replace these? It still has sufficient power to push the innards like it should since it was working before I tore into it.
Cebby, what ever came of this? I have a spring in a spare set that I am rebuilding that is very similar sounding to yours. I'd prefer to replace it if I could but can't find any posts stating wether or not it could be replaced without having to pull one from a donor.
Old Jun 16, 2006 | 05:29 AM
Cebby's Avatar
It had no effect on the operation of the hub. You'll be fine with the original.
Old Jun 16, 2006 | 06:10 AM
1985 4Runner's Avatar
Great thread, just popped up in time too. My hub gears should be here soon.
Old Jun 16, 2006 | 06:30 AM
  #25
cootees's Avatar
Thanks. Just hoping you found somewhere to find a new spring for more ease of mind.
Swim
9
Jan 4, 2016 10:47 AM
_Nicco_
Sep 21, 2015 03:06 PM
Gravel Maker
RuffStuff
Sep 8, 2015 05:46 AM
carlspeed
Aug 23, 2015 02:59 PM
jaretstuff
Aug 4, 2015 02:08 PM
