Rear heater pic?
Old Dec 13, 2004 | 08:20 PM
IamaFan's Avatar
Rear heater pic?
I was coming home from school yesterday and heard a snap, but had no idea what it was. Today I saw that the knob from my rear heater had popped off and the actual metal holding on the knob had disappeared. I also found a piece of foam which I don't know where it's from. I popped off the trim and found the rest of the lever, but I think it's bent. Can somebody take a pic of the opened rear heater so I can see if the lever is supposed to be bent, and if there's foam somewhere in there? Here's a pic for reference:
Thanks.
Old Dec 13, 2004 | 08:26 PM
Scofco's Avatar
Everything looks fine from the picture...
Stick the foam where it looks like it should go, pop the trim back on, then chuck the knob on there. Good as new
(I don't know what metal that holds the knob on that you're talking about, I thought it was just glued)
Old Dec 15, 2004 | 07:05 AM
Jason B's Avatar
It should look like this when you are done:
I added a rear light in mine, I think it needed one for after dark.
Old Dec 15, 2004 | 10:38 AM
User 051420's Avatar
The foam sticks on top of the heater lever unit. I don't think it's necessary unless you want to bust out the glue to reattach it.
Old Dec 15, 2004 | 03:07 PM
MTL_4runner's Avatar
Don't even need glue to attach the foam, it just sits in the channel above the lever.
Piece of cake, just put the foam back in, pop in the trim and put the knob back on.....no sweat!
the1998sr5
15
Jul 14, 2020 08:35 PM
jerusry
Oct 19, 2015 05:28 PM
BeMiceElf
Oct 10, 2015 09:40 PM
the1998sr5
Jul 16, 2015 06:20 AM
toyoda8488
Jul 5, 2015 10:18 PM
