Rear Axles bent!!!!! HELP!!!!!
Old Jun 14, 2011 | 08:15 PM
4x4Forner's Avatar
I ended up rolling my 97' 5 speed sr5 4runner a little while ago. got her all put back together an she don't look bad. My rear axles got bent in the roll, wondering if there are any good aftermarket axles out there and how hard it would be to replace them. was thinking about maybe going big and changing rear to disc brakes but that would involve a lot more work and money. I also don't have a locker and want one bad. so maybe i should just replace the whole rear end with a new axle that includes a locker. don't know what to do and need help
Old Jun 14, 2011 | 08:55 PM
JerrfyLube's Avatar
A direct bolt on replacement should be fairly easy to find for not a lot of coin. Check craigslist and your local yards.
Unless your running pretty big tires and wheeling it hard, there really is no reason to go bigger.
Old Jun 14, 2011 | 10:23 PM
dropzone's Avatar
Fossilized
Find one with an elocker, don't forget the wiring for it.
Old Jun 15, 2011 | 09:36 AM
BajaRunner's Avatar
Chico must have a pick n pull around right? Id just go there and pull out my own!
Old Jun 15, 2011 | 09:58 PM
cpizzle42's Avatar
easy fix. Poly performance has them cheap.
Your welcome.
Where it gets expensive is all the bearing and seals from Toyota. espically the ABS. (which I ended up not using to save $$)
Old Sep 23, 2011 | 05:00 PM
4x4Forner's Avatar
thanks for the help
88sasturbotoy
Jan 30, 2026 01:57 PM
jerusry
Oct 19, 2015 05:28 PM
gieselman
Oct 12, 2015 01:34 PM
deepmarsh
Aug 6, 2015 03:44 AM
toyoda8488
Jul 5, 2015 10:18 PM
