Rear axle leak
Rear axle leak
my rear axle is leaking right under the pumpkin.
1). is this the main seal?
2). how you fix it?
3). is this covered under 60k powertrain warranty?
4). why is it leaking?
(btw, i have extendeded the breather).
pics:
2). how you fix it?
pics:
Rear main seal
There is likely a problem with the seal in the pumpkin. It's not a terribly hard fix, but not that easy either.
I have an 87 runner and had the same problem. Had to take off both wheels & brake assmeblies and pull the axles out. Then you just take the differential housing apart and put the new seal in. I actually ripped 2 or 3 trying to get it back together cause I didn't have anyone helping me and kept ripping the crap out of it when trying to line the housing cover back up (while laying on my back).
However, no problem with leake since.
Re: Rear axle leak
2). how you fix it?
2). how you fix it?
EDIT:
from the pic it looks like your bottom nut is loose. just a thought.
FS[PacNorWest]: Rear chromoly axle shafts
A2theK
Jan 10, 2016 10:18 AM
jerusry
Oct 19, 2015 05:28 PM
Avenged
Jul 9, 2015 07:55 AM
toyoda8488
Jul 5, 2015 10:18 PM
