Quick S/C ?
Old Jan 16, 2003 | 08:42 AM
bbeast's Avatar
Quick S/C ?
Ok, this will be easy - I have a 1st gen S/C but no boost gauge. With the stock pulley, how much boost should the S/C make?
Old Jan 16, 2003 | 09:23 AM
I think
I think it is 6 psi. Then I believe they sell a 9lb pulley also.
Mike
Old Jan 16, 2003 | 09:29 AM
SLC Punk's Avatar
Re: I think
Mike
Yep its 6 psi stock
Old Jan 16, 2003 | 09:44 AM
bbeast's Avatar
Thank you both. Just needed to make sure....
Old Jan 16, 2003 | 11:54 AM
cstary's Avatar
gadget's site indicates that the 1st gen may put out a little bit more than the 2nd gen, although there is also an efficiency issue.
"they" (meaning TRD) don't make a smaller pulley for more boost, but they do have a larger, 5 psi pulley for free (to reduce pinging).
you can get smaller pulleys for more psi from pulleyboys.com, maxxautoworks (but they are scammers), and ELprototypes.
creed
Old Jan 16, 2003 | 12:51 PM
tomus1000's Avatar
The stock pulley should make about 6lbs. of boost. Don't worry about any smaller pulley to make more boost. Your stock fuel delivery system can't even come close to supplying enough fuel to keep up. You would need to do some serious fuel system upgrades to support that much boost. That is too much for that little TRD blower to be making anyway. It will become really ineffecient.
Old Jan 16, 2003 | 01:17 PM
cstary's Avatar
i ran 9psi (with 305 injectors, 190lph pump) and saw a DECREASE on the top end. most likely due to the increased temps of the discharged air . . .
that may be overcome by water injection though.
creed
Old Feb 12, 2003 | 05:32 PM
ravencr's Avatar
That's what I'm hoping will happen, Creed. I hoping I can run 370cc injectors, SMT-6, water injection, 9psi pulley, and the 190 LPH fuel pump. I'm also hoping to push 275 rwhp, but I could be dreaming.
Chris
Old Feb 12, 2003 | 05:51 PM
cstary's Avatar
i think that is a realistic goal, considering the ignition advance possibilities . . .
creed
Old Feb 12, 2003 | 05:54 PM
ravencr's Avatar
Yeah, that would be awesome! I would love to be the first person to break 300 rwhp, but I'm not sure it will work out or not. The only person I know that has been close is Duffdog, but nobody really knows the validity of Tim's claims, because no one has seen his dyno runs.
Chris
Old Feb 12, 2003 | 06:05 PM
Duffdog's Avatar
dont worry, i just got my truck back and will get re-dynoed just as soon as i get some extra time-- by the way, i heard that someone knows of a shop near the sacramento area that will dyno for like 60 dollars-- where are they and whats the number?
Tim
Old Feb 12, 2003 | 08:53 PM
Tim
Tim,
The shop is called Marco Automotive Chassis Dyno. I paid $60 for three pulls. Here is their phone number (916) 988-8105. If I remember right, you can rent the place for an hour and do all the runs you can fit within the hour and pay $120. Want to meet up?
Old Feb 13, 2003 | 03:10 AM
ravencr's Avatar
Sweet Tim! I can't wait to see your results. Keep us posted!
Chris
Old Feb 13, 2003 | 09:15 AM
Chris
Do you mean the first to break 300 with a TRD blower? Because there's more than one guy running in excess of 400 rwhp on the outdoorwire board. See the below thread...
http://www.4x4wire.com/cgi-bin/ultim...13;t=015721;p=
Old Feb 13, 2003 | 09:50 AM
cstary's Avatar
nitrous is cheating!!!
creed
Old Feb 13, 2003 | 10:08 AM
ravencr's Avatar
I agree Creed! I want 300 rwhp without the nitrous, not with it. Nor do I want to do all that stuff to the internals of the engine either, if I don't have to.
Chris
Old Feb 13, 2003 | 02:14 PM
tomus1000's Avatar
Well, if you are serious about making 300 hp at the wheels, then you will need to dome some upgrading in the bottom end of your motor. The stock internals were not made to take that punishment over the long haul.
but i developed a Cam gear seal leak and i fixed but then turned into a valve seal leak and i'm burning oil. which is all on a stock motor.
Boostedtaco is saying that he is damaging his motor by running his setup on a stock bottom end. This comment was after making 400hp with a 100-shot. That would be 300hp with no juice.
Old Feb 13, 2003 | 04:28 PM
ravencr's Avatar
I'm wondering if he has damaged it as a result of the 100 hp shot coming on so hard as it normally does, or just the standard 300 rwhp? It's hard to say isn't it?
Chris
Old Feb 13, 2003 | 04:40 PM
Blueski002's Avatar
where can you get the superchargers for the first gens? i am just curious, thanks
mike
Old Feb 13, 2003 | 04:43 PM
CTB's Avatar
CTB
i believe you can only get turbo's for them. some came from the factory like that.
kawazx636
Oct 6, 2021 03:03 PM
ladybugRC
458
Aug 21, 2020 10:41 AM
zytra
Jan 24, 2019 03:16 PM
charlie_fong
Sep 27, 2015 10:06 PM
