question (timing & air fuel mixture)
Old Jul 20, 2004 | 10:13 PM
2wd1stgen's Avatar
Situation:
85 1/2 ton pickup w/ 180k mi failed timing area of the CA smog test but passed emissions. Truck is set to 5 degrees retarded but should be 5 degrees advanced. Truck has 30% alcohol 70% cheap gas mixture currently in gas tank to help pass emission test. Timing must be set correctly and test must be redone tomorrow
Question
1 Could the alcohol in the fuel have messed up the timing or is it just off? I suspected it has been running rich but never checked.
2 When the timing is corrected could this cause the truck to stall due to the alcohol in the fuel?
3 If the timing is adjusted with 30% alcohol in the fuel will it be valid or need to be redone with pure gasoline?
Other threads I have created on this subject are
alcohol as fuel?
Please help me pass CA smog
Old Jul 21, 2004 | 07:46 AM
eric-the-red's Avatar
Check out this link, it's a guy who's done a lot of work on different fuel mixes,
http://www.turbofast.com.au/racefuel2.html
Sorry don't know enough about timing and such to offer any more help.
Old Jul 21, 2004 | 09:20 AM
roger's Avatar
I think it's just off. Don't see how the fuel could affect the timing, since timing is mechanically set. Sorry, don't know about the other two items.
Old Jul 21, 2004 | 09:56 AM
2wd1stgen's Avatar
nevermind
I passed. Just added gas just to be safe, adjusted the timing to correct setting, and passed the test.
GreenLion
Jun 7, 2021 10:49 AM
bigblue82
10
Jul 6, 2015 08:27 AM
94hiluxZE
Jun 22, 2015 10:42 AM
saphirekosmos
Jun 22, 2015 10:26 AM
