project overhaul - 02 4runner
Old Dec 24, 2008 | 09:31 AM
twitchee2's Avatar
I went to look for tranny fluid yesterday along with rear diff fluid. Im not sure what tranny fluid to get, is it destron 2 or 3? as for the rear diff fluid, will 75-90 work? or do i need just strait 90?
Old Dec 24, 2008 | 10:06 AM
cackalak han's Avatar
Since you're doing an "overhaul", you're probably going to do a transmission flush, right? If so, you need to know what you're doing. Be very careful, as you could burn up your auto transmission. I just took mine to the dealership to do the flush (it was like $60-70 or something).
For the diffs, get 75w-90. I also have Amsoil in all my diffs and x-fer case.
Old Dec 24, 2008 | 10:56 AM
twitchee2's Avatar
im debating if im gonna flush it or not. at this point i was planning on just doing a drain/ refill but i think be best to just go get it flushed
Old Dec 24, 2008 | 05:09 PM
1960 BJ type 25's Avatar
Nice I will be most of this Jan.
Old Dec 24, 2008 | 05:22 PM
  #25
904_runner's Avatar
What about the highlakes run for part of your overhaul?
Lol
Old Dec 24, 2008 | 09:56 PM
  #26
twitchee2's Avatar
Lol
dude im so down, minus the part im down at my parents in socal for all of winter break....
Old Dec 25, 2008 | 03:51 PM
  #27
twitchee2's Avatar
When i take the struts out, should i get new top plates or can i just reuse the ones that are there?
Old Dec 26, 2008 | 07:37 AM
  #28
twitchee2's Avatar
bump for the top plate question. I'm about to go get started.
Old Dec 26, 2008 | 08:37 AM
  #29
okie81's Avatar
Looks like you're running a lot of synthetic fluids, have you considered synthetic transmission fluid?
Old Dec 26, 2008 | 10:14 AM
  #30
Ron Helmuth's Avatar
3rd gen grog-the rear diff breather is a "vent" that lets excess pressure escape out while not allowing water in. Many of us have extended the vent up to our fuel filler door area so there is no chance of water coming in during a water crossing. The front diff already has the vent extended to the firewall area I am told/have read.
Old Dec 26, 2008 | 11:09 AM
  #31
Ron, just lift up your hood and check out the driver's side firewall area. You can see the two breathers there.
Old Dec 26, 2008 | 11:10 AM
  #32
I just reused them. No need to replace unless they are damaged.
Old Dec 26, 2008 | 11:34 AM
  #33
Cool thanks cack
2 of them? both for the front?
sorry I am thread hijacker
Old Dec 26, 2008 | 04:36 PM
  #34
twitchee2's Avatar
thats what im going to do.
Everything went well today until i went to lunch took the struts to get assemlbled. got there, found out i left the top plate spacers right where i left them on the table...had to go with my friends to run a few arrends. Got home, ran back to the shop where the guy had already gone home for the day. Got back and looked at the ball joint i installed and found out i cracked the bottom because the press i was using was the wrong one apparently.....
but other then that the rear came out great, im just going to take to my buddies and weld the pan hard drop in just to be safe. i also need to get a couple more tools. Gotta get a different ball joint puller, pickle fork, 19mm wrench and a 14mm ratcheting wrench. whoopy. still lots of fun and a great learning experience, i was taking my merry sweet time and had the rear done in 2 hours that included the PITA airbags and air lines, took all of 10 min to get both front struts out. anyway. off to the track tomorrow and im putting the rest on hold till monday, hoepfully i can get my dad to take the struts in to get assembled for me, that would be sweet.
Old Dec 27, 2008 | 06:56 PM
  #35
twitchee2's Avatar
ended up going to the track to take pics for my friends came back and took struts to a guy to assembled...well he coudlnt do it so i have to wait till monday..... I did how ever go get a new ball joint and got them installed so that is done. Plan for tomorrow is to get the diff drop in and get the fluids done, maybe ill get some pics up sometime.
Old Dec 30, 2008 | 02:44 PM
  #36
twitchee2's Avatar
picture time
Old Dec 30, 2008 | 02:50 PM
  #37
904_runner's Avatar
^ Nice
Looks too pretty to scratch up in the mountains!
Old Dec 30, 2008 | 03:05 PM
  #38
twitchee2's Avatar
haha you cant see it, theres LOTS of pin striping and it got keyed when the PO had it.
Old Dec 30, 2008 | 09:18 PM
  #39
02_Limited's Avatar
I'm loving the look of that, can you PM me the list of things you bought and have installed in those pictures? I see my money needs to go towards a lift and not a bull bar
Old Dec 30, 2008 | 09:23 PM
  #40
twitchee2's Avatar
all i have is OME 881 front and 890 rear springs and front top plate spacers, all the standard OME shocks, Stock tires, and then just some $20 harbor freight lights i cant believe are still working.
Flying91
45
Apr 11, 2024 04:39 PM
icentropy
Sep 16, 2020 02:47 PM
jasonty
41
Dec 23, 2018 01:00 PM
BeMiceElf
Oct 10, 2015 09:40 PM
dropzone
Jul 11, 2015 10:17 PM
