Pro Engine Cleaning Technique
Old Aug 6, 2004 | 05:26 PM
mt_goat's Avatar
Originally Posted by YotaTruck1986
BigBlob202 showed me this technique for detailing your engine.
Pictures copyright of http://www.srcstc.com/
Some of you may use this technique, some may not, but here it is.
1. Run your engine for a few minutes to warm (not hot) it up. The grease and dirt can be removed easier when its warm.
2. Second, cover all parts inside you engine that CAN'T get wet with tinfoil or plastic bags and rubber bands. (Distributer, alternator, electronic connections, etc.)
3. Spray EVERYTHING with a degreaser. (I use Simple Green Degreaser.) Use the whole bottle, don't hold back. Let it sit for 15 minutes, the degreaser has to have time to do its magic.
4. Rinse your engine lightly with water to remove the crud and cleaner.
(Repeat steps 3 and 4 until you get the results you want.)
5. This step is key! Grab a bottle of WD40 and spray EVERYTHING. Wipe away any excess. You'll probably want to empty the can. This will give everything a newer than new glossy shine. All your faded plastic and tubing will come back to life. Don't rinse the WD40 off with water, leave it as is.
You can also use Pledge if your afraid the WD40 might atract dust.
6. Remove all tinfoil or plastic before driving.
Here's a before and after picture using this technique.
BEFORE:
AFTER!:
Be sure to post any before and after pictures you might have if you try this. If you have any comments or suggestions, please post! Thanks.
Hey I recognize that BMW oil filter cover, but that can't be a BMW air filter. Hope you covered that good before the bath.
Old Aug 6, 2004 | 05:43 PM
YotaTruck1986's Avatar
Thats not my engine. It's just a before and after picture using that technique. Its from http://www.srcstc.com/
Old Aug 6, 2004 | 06:01 PM
FirstToy's Avatar
Boeshield is awesome for the engine, suspension and drivetrain. Cleans and protects really well- all metal actually- and cleans up plastics really well too.
Old Aug 6, 2004 | 06:54 PM
ldivinag's Avatar
what's this cleaning the engine thing... i never heard of that before...
Old Aug 6, 2004 | 06:55 PM
  #25
RagerXS's Avatar
Some of the guys on the Miata.net board mentioned that Armor All's Tire Cleaner makes for a great engine cleaner that is also inexpensive and leaves the plastic/rubber parts looking great.
~ Fred
Old Aug 6, 2004 | 07:30 PM
  #26
4-RUNNIN' FREAK's Avatar
I skipped the shiny stuff part. I didn't want to tempt spraying stuff and getting it on the headers or engine and later catching fire. Who knows with all these chemicals. Plus when it starts to burn off and some nice happy fumes are flowing through my vents.
The stuff I used finally in full strength worked wonders.
Old Aug 6, 2004 | 07:38 PM
  #27
Speaking of WD40 on headers, a good trick to play on someone (if you can get their hood open.) is to spray a little bit of WD40 (NOT A LOT) on the headers. When they start up their engine the oil in the WD40 with get hot and turn into thick white smoke, that will billow from under their hood. It's probably a very stupid idea because of the fire hazard so *don't try this at home!*
Old Aug 7, 2004 | 01:30 PM
  #28
MvCrash's Avatar
Greetings,
Would'nt the stuff you shine your tires with work well on the rubber in an engine compartment? Is it really ok to spray WD40 on Everything? I like a detailed engine and just used gunk and elbow grease and lots of cash to buy braided hoses so if this works, I'll save a ton of money on my Taco.
MV
Old Aug 7, 2004 | 04:50 PM
  #29
MV, where in NNJ are you from?
Old Aug 7, 2004 | 05:10 PM
  #30
Originally Posted by MvCrash
Greetings,
MV
The Tire foam works well also. My brake cylinder was somewhat faded and patchy, but now its a clean flat black. WD40, Pledge, and tire foam all work well on rubber and plastic.
Old Aug 7, 2004 | 05:23 PM
  #31
Originally Posted by Donovan
The problem with the simple green is that it will EAT the hell out of aluminum and remove the protective coating on a lot of metal parts, leaving them more prone to oxidization. Also WW40 is very flamable so be carefull when you drive the truck with that much on there Steam cleaning and dumping some finish 2000 is a safer way to get this done.
Not only will it eat that, It really messes up the skin on my hands in a parts washer. I use the rubber gloves and all and where they stop, my skin gets messed up. And I used to use the yellow housewife gloves, and they really stretched out and after a lil bit, had holes in them.
In my old job at the company I worked for, I used to paint traffic lines. Simple Green would eat the thermoplastic right off. It would just peel off. With that said, I don't know how that stuff can be safe for the environment.
Old Aug 7, 2004 | 06:17 PM
  #32
MvCrash's Avatar
Greetings,
Your ten minutes from Manhattan according to your info, I'm about 5 Minutes depending on traffic. I live near the Bridge, I can actually throw a stone and hit it.
MV
Old Aug 7, 2004 | 06:34 PM
  #33
Greetings,
MV
I can make it into NYC in 10 mins from my door to the end of the tunnel.
Old Aug 8, 2004 | 04:02 AM
  #34
MvCrash's Avatar
I take it thats the GWB. I work for them.
I take it you're in Fort Lee?
I'm in Bayonne. I can make it into NYC in 10 mins from my door to the end of the tunnel.
You have a PM
Mv
Old Feb 1, 2006 | 12:10 AM
  #35
CANADA4RNR's Avatar
From: Beautiful British Columbia 1994 v6 3.0 4x4 auto
I did the Degreaser (gunk citrus) then the wd40 and it worked great.....but I was a little concerned about the fact it is flamable so i washed it off before I went for a drive. Also i have heard that wd40 is harsh on rubbers and plastics?....I am wondering how well "gunk" "liquid wrench" would work? same kinda product as wd-40 but It comes in a non-flamable version.
Old Feb 1, 2006 | 12:34 PM
  #36
Runner003's Avatar
All THe toyota's that I've owned get a engine wash 3 -4 times a year, just using power washer, Gunk, finish 2000, Its amazing the crud that builds up on a engine, a clean engine is a happy engine.... With the Engine clean it helps working on the regular mainenance.
smthwsn357
May 1, 2024 07:28 AM
icentropy
Sep 16, 2020 02:47 PM
Sep 4, 2015 09:27 AM
razorman8669
Jul 12, 2015 12:13 PM
tpd143
Jul 7, 2015 09:06 AM
