power steering only works when gas is applied??
Old Feb 22, 2006 | 05:14 PM
dexter's Avatar
this started up today when i got in my car. if i try and turn the wheel its really hard ie no power steering. if i give it just the tiniest bit of gas it kicks back on. does anyone know what is causing this. also if the car is in neutral it works fine. low fluid? bad pump? vacum hose pop off??
Old Feb 22, 2006 | 05:26 PM
Rick F.'s Avatar
From: Far western Kentucky (transplanted from central PA)
Could be a slipping belt. And it sounds like any minor increase in engine speed above idling in-gear kicks the pump in. Have someone shift from drive to neutral while you watch the PS pump and pulley.
Old Feb 22, 2006 | 06:00 PM
bigacuralvr's Avatar
I would vote bad vacuum hose....
Old Feb 22, 2006 | 11:04 PM
KyleT's Avatar
mine does that, but only when i turn to the right, and its intermittent, at teh most inoportune times no less.
Old Feb 23, 2006 | 03:07 AM
GSGALLANT's Avatar
I agree... check that out first.
Old Feb 23, 2006 | 04:19 AM
Rick F.'s Avatar
As an afterthought, what is your idle speed when in-gear? Is it possible that your idle speed is so low that the PS pump isn't maintaining system pressure? That might explain why it kicks in when in PARK or when you increase engine speed also.
Old Feb 23, 2006 | 10:27 PM
dexter's Avatar
hmm all good possibilities
voiddweller
19
May 2, 2016 09:10 PM
Bamripzit
Jul 19, 2015 01:17 PM
Bamripzit
Jul 13, 2015 07:21 PM
1badyota350
Jun 28, 2015 06:50 AM
paxanders
Jun 21, 2015 06:29 AM
