Power Antenna fixed! Thanks Bob!
Originally Posted by Bob_98SR5
4Runna,
Yer welcome
So did you fix the antenna or did you replace it w/ the fixed mast?
Bob
Yer welcome
So did you fix the antenna or did you replace it w/ the fixed mast?Bob
I know it's not a question of "if", it's "when"...
Might as well throw some thanks your way as well!
I did the mod about a month ago. It worked perfectly. Only "bad" things was I used it as an excuse to upgrade the entire sound system in the 4Runner...I mean might as well since I was basically removing the radio anyways
Still using the steel whip the new base came with but I will install the fiberglass Taco one of these days...just cant justify the 35 bucks yet but I know I will soon enough.
Great write up and easy to do!
montanatruck
Feb 26, 2017 07:07 AM
lfcarrion3
Jul 18, 2015 04:05 PM
toyoda8488
Jul 5, 2015 10:18 PM
