Post your axle code!
Old Nov 28, 2005 | 09:50 AM
  #61
woodworth's Avatar
94 runner automatic G144, from the factory w/ 225-75-15 and 4.88's and now running 31-10.5-15's. and its only a pain on the hiway doing inclines.
woody
Old Nov 28, 2005 | 10:26 AM
  #62
hayduke's Avatar
94 pickup, 4x4, 5-speed, standard tire size. B03A.
Old Nov 28, 2005 | 10:49 AM
  #63
bob200587's Avatar
G292 4.10 225s
Old Nov 28, 2005 | 10:56 AM
  #64
AgRunner06's Avatar
woody
That doesn't seem right. If your factory tire is 225 then you should have 4.56s not 4.88s. 4.88s came with 31" tires from the factory.
Old Nov 28, 2005 | 10:58 AM
  #65
nrgetic99's Avatar
1993 SR5 V6 4WD with a stick.
G254.
8", 4.559:1, 4 pinion open.
David
Old Nov 28, 2005 | 11:58 AM
  #66
hayduke's Avatar
is there a 4runner lsd that would be a strait swap for my application?
wouldnt mind some 4.56 to run larger wheels.
whats the axle code for lsd?
Old Dec 1, 2005 | 05:05 AM
  #67
woodworth's Avatar
AG, does seem funny but thats what the door sticker says. maybe thats because of a tow package, i'm guessing.
Woody
Old Dec 3, 2005 | 05:59 PM
  #68
hektikwon's Avatar
You guys with factory 4.56 and 4.88 are lucky. If I only knew what to look for before I purchased... G294 a340h 3.0. Wait I mean 5spd 3.4. Ha!Ha!
Old Dec 4, 2005 | 12:52 AM
  #69
4RUNN!N's Avatar
I have a 97 Toyota 4Runner Limited 4x4 with the e-lockers, and my code is A04A. That suggests I have 4.56 with a 2-pinion. Right?
Old Jul 22, 2009 | 06:05 PM
  #70
FoneRunner's Avatar
I have a 98 4Runner Limited with elocker and my code is A04A...one website says I have 4:56 and the other says I have 4:30....I guess its time to spin the wheel and count the revs!
Old Jun 22, 2011 | 06:29 AM
  #71
badattitude's Avatar
on my 1999 the axle code is A03A
03=4.10
A= 2 pinion
I think I have a 4.10 but I know my truck had a 4 pinion open diff becasue I took it out and saw for myself.
Old Mar 31, 2012 | 12:24 PM
  #72
Roxana Reyes's Avatar
2nd Generation 4Runner.
Hi, guys I'm new here just wanted to share I have a 1990 4Runner 2WD automatic. My code is G252/A44D. Can anyone help me figure out with rear differential I have? Also I am in need of a new one so if any of you have one for sale in the Los Angeles area or can direct me in the right way greatly appreciated. Thanks
Old Mar 31, 2012 | 12:57 PM
  #73
MudHippy's Avatar
Mine is G292. But it's not correct. It should be G294. Because the rear axle it came with actually has a 4 pinion differential with 4.10 gears, confirmed by disassembly. Which is as it should be, since it's a V6. So...
Axle code: G292(incorrect should be G294)
Stock gears: 4.10
Stock tire size: 225 75 R15
Engine: V6(3VZ-E)
Transmission: Manual(R150F)
The link to that site has been changed, and it's a little outdated to boot, so here's this:
Old Apr 1, 2012 | 06:22 PM
  #74
photoleif's Avatar
G254=4.56. kinda wish i had 4.10s because then a re-gear would be an obvious upgrade. as it is, 4.56 to 4.88 yields a not stupendous cost-to-performance gain.
Old Apr 2, 2012 | 05:39 AM
  #75
Inverno4's Avatar
B03A stock
Old Apr 5, 2012 | 09:33 PM
  #76
Ugh I'm confused now. If some cars are label incorrectly it's all about trial and error I guess? I'm heading to the junkyard tomorrow and now I don't know what to look for. On my door jam it states G252/A44D. My 4Runner is a automatic 2wd 22re engine non ABS. Will a 4x4 rear differential fit my truck without any modifications if it's the same gear ratio?
Old Apr 6, 2012 | 11:12 AM
  #77
MudHippy's Avatar
Your axle code is G252. Which means you have an 8" 2 pinion differential w/4.56 gears.
A 4WD rear differential will fit your truck. And since it's a 4 cylinder 2WD, the gear ratio and/or the number of pinions it has don't matter. They're all 8" having 2 or more pinions(the more the better), and will fit anywhere another 8" will fit.
Simple enough?
Not so fast...
You might have to swap the companion flange from your old one for it to match your driveshaft bolt pattern. That's the only thing that might need "modification". But it's a fairly simple procedure should the need arise.
Old Apr 6, 2012 | 11:38 AM
  #78
PhdNPrerunners's Avatar
Originally Posted by servo_fan
Is your Tacoma an auto or manual? I initially thought that the gear ratio was based solely on your transmission, so for example 4Runner's with manual trans would be running 3.90 gears and the autos would be running 4.10, (4.30 with the rear locker), regardless of stock tire size.
Maybe the Tacomas are different than the 3rd gen 4Runners, but yours came with 225/75s and 4.10 gears. That's why I'm wondering about your transmission.
Is the gear ratio a combination of transmission and stock tire size? Not knowing what transmission is in the Tacoma it doesn't appear to be tied strictly to tire size if that 96 Tacoma came with 225s and 4.10 gears.
Could you have an automatic with 225/75s running 3.90 gears? Could you have a manual with 265/70s running 4.10 gears? Are there manuals with 225/75s running 4.10? (I don't think this one is possible but you never know!).
Thanks.
MY 99 Tacoma came from the factory with 225/75, A03A, and its a manual. I was very happy to find out my base model tacoma has 4.10s
Old Apr 6, 2012 | 01:31 PM
  #79
Differential gear ratio color codes
So I get to the junk yard this morning and no luck all the differentials were gone. In the parking lot I seen I guy that had a differential off a 2nd generation 4Runner. He asked me what color differential I was looking for? He had a yellow one? Does anyone know what color code each ration has? Is it accurate? I got the guys number incase I can use the one he had. Thanks again
Old Apr 6, 2012 | 01:59 PM
  #80
MudHippy's Avatar
Yellow should be 4.56 gears.
http://www.4crawler.com/4x4/4R_TechI...#Differentials
