Post clutch return spring install issue
Old Feb 12, 2006 | 08:01 PM
LV91T's Avatar
Clutch pedal hitting floorboard instead of clutch switch!
OK so I changed out the clutch return spring bushings and now the pedal is hitting the floor board before hitting the clutch switch - so I have to use the clutch bypass switch to start it. I pulled out the clutch pedal assembly a second time and reinstalled it, and I've tried adjusting the clutch pedal and its still happening. All I can think of is:
a. I tightened the 12mm nuts on the master cylinder too much.
b. Maybe I should add some washers to that spot.
c. Master cylinder has shifted out of wack.
What do you guys think? I hate to keep using the clutch bypass!
Hadrian
Old Feb 15, 2006 | 10:51 AM
LV91T's Avatar
bump... someone must have replaced this bushings before
Old Feb 15, 2006 | 11:15 PM
msw0085's Avatar
there is a write up.. search for it
Old Feb 15, 2006 | 11:17 PM
msw0085's Avatar
https://www.yotatech.com/forums/show...clutch+bushing
Old Feb 18, 2006 | 10:44 AM
LV91T's Avatar
I think I need to change this title to "Clutch hitting floorboard instead of clutch switch"
The issue is not how to install the bushings... but instead after replacing the bushings, and reinstalling the clutch pedal assembly, the clutch pedal is now hitting the floor board before hitting the clutch switch. This forces me to use the clutch bypass switch to start the car!
I've read numerous write ups, forum posts, and newsgroup posts and nothing refers to this... except maybe that the MC may move around so I'm guessing thats it.
I'm about to pull it out for the third time but was hoping someone had some input on this.
Thanks - Hadrian
Old Feb 20, 2006 | 11:43 AM
LV91T's Avatar
Well moving around the MC didn't help at all... I'm going to pick up some washers and install them between the clutch pedal bracket and the firewall... but that just doesn't seem right. Any ideas guys? I'm dyin here
bigjstang
Jun 2, 2025 03:56 PM
Jun 1, 2021 01:51 PM
Regency
20
Jan 3, 2020 07:43 PM
HBoss
Jul 1, 2002 09:54 AM
