Is it possible !
Old Jan 16, 2003 | 04:21 PM
swerks's Avatar
Is it possible !
could the source of my rattle be a loose antenae motor in my front fender?? Has any one had this problem ? Is there a way to tighten things up Im running out of possible sources:cry:
Old Jan 16, 2003 | 06:45 PM
Mattimus's Avatar
Does it rattle when you shut your door? I know I hear a rattle on mine from the right front fender area when I shut my door. It use to be annoying but I'm use to it now.
Old Jan 17, 2003 | 02:33 AM
swerks's Avatar
It rattles when I go over bumps, mainly when its cold out side. sounds like it could be in my fender or inside my door.
Old Jan 18, 2003 | 07:49 AM
swerks's Avatar
No one has had a loose antenae motor??? I was hoping some one else may have experienced this before I start tearing things apart,:confused:
Old Jan 18, 2003 | 10:57 AM
PhxTRDRunner's Avatar
It is right behind the inner fender, I doubt you even have to take the tire off...probably a couple phillips or 10mm's and it'll fold right out of the way and you can give it a quick grab to see if its loose...worth a try IMO.
Old Jan 18, 2003 | 12:01 PM
swerks's Avatar
I know this would not be too difficult to check out but the wheel well is held on with kind of a clip that are supposed to be a pita. I just thought if no one else had ever experienced a loose motor mech. I would move this down my list of things to check out. thanks for all input. :confused:
Old Jan 21, 2003 | 05:54 AM
swerks's Avatar
Any one know the part # on the clips that hold the fender liners in??:confused:
Old Jan 21, 2003 | 08:49 AM
Mattimus's Avatar
Did ya' break um??
Old Jan 21, 2003 | 10:17 AM
swerks's Avatar
Not yet, but the way things go for me, I thought I woulod be prepared. plus there is one already missing.:confused:
