poor gas millage and gas smell, with a p0171 code
Old Jan 26, 2013 | 08:41 AM
  #41
Josh843's Avatar
poor gas millage and gas smell, with a p0171 code-forumrunner_20130126_123801.png found the culprit for the idle problem huge vacuum leak on the power steering pump thing where there are two vacuum lines!
Old Jan 26, 2013 | 05:59 PM
  #42
youngtoyotatech's Avatar
That is probably the cause for the lean code too. Fix that, disconnect battery to clear codes and trims and see if the mil comes back on.
Old Jan 27, 2013 | 07:29 AM
  #43
Josh843's Avatar
Already did and it's running way better now and no CEL so far, drove it pretty good yesterday and no problems, I had to use jb weld to attach the little nozzle thing that sticks out for the line to go over, and idea what this part is and where to get it from? Besides a stealership?
Old Jan 27, 2013 | 08:41 AM
  #44
If i remember right that part just threads into the power steering pump. Could try an auto parts store but they may not sell it alone from the pump. Or if you found one at a wrecking yard
Old Jan 27, 2013 | 09:14 AM
  #45
98SR54RUNNER's Avatar
If you're in Charleston (843), LKQ had a couple 4Runners there last time I was there, both still had PS pumps on them. You could also check Blue and Gold on Red Bank Rd. in Goose Creek.
Old Jan 28, 2013 | 04:01 AM
  #46
Josh843's Avatar
Yea that's the part, I guess I'll try blue and gold, I've had pretty good luck withthem before , I just don't want a brittle old one that's gonna do the same thing laterddown the road, but I do need a new console so maybe that'sa good excuse ! Where are you you from 98?
Old Jan 28, 2013 | 07:31 AM
  #47
From the Upstate, went to USC, lived on the Peninsula/JI for 3 years, just moved up to Goose Creek while job hunting. Where you at in the 843?
Old Jan 28, 2013 | 07:39 AM
  #48
Josh843's Avatar
I'm in moncks corner, I'm actually in goose Creek this week working, I work at BEC doin a little cross training this week, oh joy
Old Jan 30, 2013 | 04:33 AM
  #49
Berkeley Electric? Sounds like fun! Haha. PM me or something if you ever want to do a maintenance day or some light wheeling. My buddy has a '94 LT1 that's fun to play with too if you're ever over this way.
Old Feb 5, 2013 | 05:14 PM
  #50
Dreidel's Avatar
i fixed my mpg pronlem the other day just by reseting the ecu and now im getting like 25-26 in town
is there a trick to finding vacuum leaks or is it just looking very hard for the leak
Old Feb 5, 2013 | 05:17 PM
  #51
HighLux's Avatar
Dreidel...use a propane torch...unlit....turn on the gas..and point it at all vacuum line/gasket areas.....it will rev up from propane if there is a leak.
Old Feb 5, 2013 | 06:29 PM
  #52
Dreidel's Avatar
ok cool thanks im just glad i fixed for the most part my mpg problem simply by resetting the ecu (kinda sucks because today i was offered to good o2 sensors off a camery but ill save them for later)
Eggslinger
Jun 8, 2019 03:32 PM
crammit442
7
Nov 29, 2017 12:30 PM
raptor510
Feb 17, 2017 07:11 AM
raptor510
Aug 19, 2015 02:15 PM
nonstop
Jul 24, 2015 06:29 PM
