polishing wheels
Old Mar 21, 2007 | 05:46 PM
kenai's Avatar
polishing wheels
I picked up a set of limited wheels today to replace my sr5 ones with the flaking clear coat. The new wheels are spotty and the glare changes on the spots......didn't looks so bad in his dark garage! Any ways to help them or is it stuck that way? thought that getting them powdercoated black but that may be mucha $$.
Old Mar 21, 2007 | 06:05 PM
lftd_86_yota's Avatar
I spose if you polished hard enough with steel wool and some wicked polish you could take the clear coat off unifromly and it wouldn't look too bad, would produce an amazing shine, but when the light hits is jut right it'll shine a little I had to go this route on my b2200
Old Mar 21, 2007 | 06:39 PM
pattycakes77's Avatar
the clear on my wheels was coming off so i stripped it all off with some "aircraft coating remover" in an spray can. i found it at a paint shop or at the autozone too. it's nasty stuff so don't get it on your skin, breathe it in, or get it on any painted or plastic surface you don't want ruined. took the clear off really well. once i got it all off i used a product calle Wenol, an electric drill, and a cotton wheel to polish the aluminum. one problem though, if you don't re-clear with something good, the shine won't last unless you keep polishing. i used some very mild cleaner and soap on my wheels afterwards and it dulled and streaked them. i would suggest not using duplicolor clear, didn't work for me. i did like the POR 15 clearcoat product though, hard as nails but a bit hard to get a nice coat on unless you have a paint gun/sprayer.
that's my $.02, good luck
patrick
Old Mar 21, 2007 | 08:24 PM
kenai's Avatar
thanks, i may give that a shot with my old wheels first to see how it works out. Are the limited wheels clear coated also? thanks!
Old Mar 21, 2007 | 08:32 PM
1989toy4wd's Avatar
Its not that hard to paint rims...and its easy touchups and cheap too I spent like 30 bucks for all 4 wheels!! there is a good right up on here, look under there for painted wheels!! take a look at mine on my sig...(they were dirty in that pic...lol)
Old Mar 21, 2007 | 08:33 PM
1989toy4wd's Avatar
BTW i used duplicolor high heat for everything primer, paint, and clear!! FWIW
Old Mar 21, 2007 | 09:06 PM
Nic's Avatar
Nic
This is basically how I removed the clear coat on mine:
http://home.off-road.com/~kemanuel/S...l/SR5Wheel.htm
foampile
Dec 18, 2022 01:29 PM
jasonty
41
Dec 23, 2018 01:00 PM
Dakotaneu
Aug 15, 2015 07:24 AM
Up&Down
Aug 5, 2015 06:20 AM
Dakotaneu
Jul 27, 2015 12:03 AM
