Pinging problem
Old Sep 1, 2003 | 05:51 PM
arjan's Avatar
Pinging problem
I have a '97 4runner (3.4L) and it pings quite a bit. It is allright when I run 92 octane but even with 89 (chevron) it pings lately when entering the highway in 4th gear. The engine is also very noisy when I hold the gas pedal at the point that the engine is not working, but I am also not engine breaking.
The toyota dealer told me that it suffers from piston slap. Is that the noise I would hear. It is not noisy when its cold. All the symptons usually start when it is warmed up.
I did do the deckplate mod & have a amsoil filter. I also took out the "mufflers" from the air intake pipe.
When I hit the gas it seems to hiss a little. Is this common to other people who did those mods?
I read on the net that a plugged catalytic converter would do this to, but I don't know if the other symptoms go with a plugged cat.
I just changed the spark plugs (used to be bosch single ground tip) and I changed them with toyota plugs with the dual ground.
The truck has 140000Km (approx 90Kmiles) on the odometer. I feel i shouldn't have those problems. I don't really enjoy driving the 4runner lately and prefer the girlfriends golf. I don't like this trend and would like to figure out if the engine has a serious problem or it is something like timing, plugged cat etc.
I know this is getting long but I tried to get as many details as I can think about right now.
Hope somebody has some ideas
Thanks for reading so far
Arjan
Old Sep 1, 2003 | 06:17 PM
MTL_4runner's Avatar
Your engine definately has classic pinging under load symptoms.
I would take off the ISR mod and see if that cures the pinging.
I have almost the exact same setup and tried the ISR and it started pinging too so I went back to stock.
The deckplate mod should be fine and so should the amsoil filter.
Old Sep 1, 2003 | 06:20 PM
Rick F.'s Avatar
From: Far western Kentucky (transplanted from central PA)
I'm no expert, but here's my 2 cents:
1. timing not set properly or advance is defective
2. carbon build-up
3. Toyota's equivalent to an EGR valve is defective.
Old Sep 1, 2003 | 07:32 PM
arjan's Avatar
Thanks for the replies.
I just inserted the factory pieces to the air intake tube. The 4runner is for sure a lot less noisy. Kind of nice. I didn't notice any performance loss so maybe the loud sound just makes it feel faster!!.
It still pings I also looked for the egr but apperently mine doesn't have one. I checked the haynes manual and it show that some vehicles have it and others don't. Does that mean that my vehicle has another sort of exhaust recirc. system???
I already tried some stuff to decarbonate the engine. I am not sure if it did anything. The spark plugs I took out looked pretty clean.
I am afraid to bring it in to the dealership to let them try a lot of expensive part & procedure until they find it. The first thing they wanted to do is a fuel system flush to clean the injectors & they claimed that decarbonizes the engine.
I hope somebody can shine some light on my problems
Arjan
Old Sep 1, 2003 | 07:40 PM
Gadget's Avatar
My first suggestion is to get a Snap On Motor Vac carbon depletion service. That will clean the injectors, intake valves, and the combustion chamber and will restore the truck to like new performance. It is called the Viagra for engines.
To check the cat to see if it is clogged is real easy. Hook up a vacuum gauge. note the vac at idle. The rev and hold the engine at 2500 RPM steady. The reading should be the same on the vac gauge or more vac. If it is less you have a valve timing problem or an obstructed exhaust.
Gadget
www.GadgetOnline.com
Old Sep 1, 2003 | 07:52 PM
Albuquerque Jim's Avatar
Gadget, can you tell us more about the
Where can you get this done???
Old Sep 1, 2003 | 08:12 PM
Gadget's Avatar
At any shop that provides the service. You may have to hunt around for it. There are other simular services, but the Motor Vac is the best bar none.
I had it done to my Maxima for the second time at 240,000 miles and it runs just like it was brand new. I have recommended it to lots of people and they ALL have reported a positive result.
Gadget
Old Sep 1, 2003 | 08:16 PM
Thansk, I just got my emissions check done and the guy commented that I probably have a lot of carbon build up, which doesn' make much sense to me because I tend to "blow it out" quite often.
Maybe that will help me, what does it usually run ($) ???
Liadrin
Apr 25, 2022 02:54 PM
theking11863
Mar 19, 2016 09:36 PM
Logz808
Jul 26, 2015 07:09 AM
Jonny246
Jul 24, 2015 12:37 PM
kyletbert
Jul 17, 2015 11:39 AM
