Pace Edwards RollTop Tonneau?!?!
Old Aug 1, 2003 | 12:19 PM
Has anyone ever used one of these? Specifically with a Tacoma dbl cab? It sounds like a great in-between, but there has to be some pros and cons. Any input is appreciated.
Also, with a stock tacoma (dbl cab sr-5 trd v6) what are some of the first mods people do? I'm a noob with trucks, as i've only owned mustangs till now.
Thanks,
Rob
Old Aug 1, 2003 | 04:57 PM
turboale's Avatar
Not sure what brand it is, but we have a roll cover on our 2500HD Chevy at work. Its a great invention. You can keep it locked in any position, and you can lock it down. Kind of a good idea if you need to put anything worth anything in the back. I would get one if I had money to burn and had a truck. It came on the chevy, so don't know about price and all of that. I know you can get electric ones too that you can operate from a keyfob. Kinda neat... as for earily mods... First thing is some good tires, then LIFT IT!! Or do both at the same time so you can get bigger tires
Old Aug 1, 2003 | 09:12 PM
rimpainter.com's Avatar
I used to install them. Pretty good quality, but a bit overpriced.
Be sure to get a locking tailgate handle ($25) or you will completely defeat the purpose of the roll-top with lock.
Old Aug 4, 2003 | 10:47 AM
thanks guys... i'll check them out a bit more. a bit pricey, but seems like the best in between of open bed easily sealed. i just dont like the retractable soft tonneaus...
Old Aug 4, 2003 | 01:56 PM
jjdeneen's Avatar
um even if it does lock, it is soft
if that is the case couldnt i come along with a razor sharp box cutter and slice and dice my way into it and steal all of your goodies....?
why not a fiberglass cover, i would imagine they would last longer also, no rips, tears, fading and getting all brittle from the sun
my .02
Old Aug 5, 2003 | 08:32 AM
The Pace Edwards Roll Top is not just a "cut and play" deal. You would need a saw to cut through the material and make a big enough hole to steal stuff. It not just vinyl. There is a backing on it. Granted, fiberglas would be much safer.
94ofCanada
Aug 14, 2015 06:37 AM
