P0305 Fixed
Old May 31, 2007 | 04:37 PM
carlj75's Avatar
P0305 Fixed
I had a cylinder #5 misfire for the past couple of days. I changed the plugs, air filter, fuel filter. I also tested the coil packs and injectors. They were all within spec, but I still had the misfire. Today I bit the bullet and took the truck into the dealer. They found that the #5 cylinder coil pack wasn't contacting the spark plug as it should and some of the spark was going around the plug, not through it. There was a slight carbon line on the ceramic portion of the new spark plug. Just thought I would throw that out there as it seems like there a lot of misfire problems out there. I thought for sure that I would be buying a new injector..
Old Jun 1, 2007 | 01:30 AM
alotawatts's Avatar
So you had a loose #5 coil pack ? How did you test the coil packs and injectors ?
Old Jun 2, 2007 | 11:12 PM
carlj75's Avatar
Yeah, I guess it was loose or something. I tested the coilpacks and the injectors with a multimeter, but the bad coilpack still tested within spec.
crammit442
7
Nov 29, 2017 12:30 PM
Peevedkitten
11
Aug 31, 2015 06:57 PM
hollypots
North Carolina
13
Aug 31, 2015 04:08 PM
izzmee
Aug 17, 2015 10:20 AM
