P0125 code HELP!!!
Old Mar 28, 2009 | 02:44 PM
mswenso1's Avatar
P0125 code HELP!!!
OK, so I have a 2000 4runner, supposedly from Arizona, that has a CEL. I pulled the code with an OBD II scan tool and it said p0125 insufficient coolant temperature for closed loop fuel control, here is my issue...
I have searched and it seems it could be a couple of things:
1) A/F sensor
2) o2 sensor
3) sticky thermostat
4) low coolant
My question is, how should I go about this...I don't have any other codes and after I cleared it, it took a while to come back on (it came on while I was on an on ramp to the highway). Also, how would I find out if my 4runner was originally a Calif. Emissions vehicle. I was told it only had one previous owner but who knows?
Thanks for the help....
Old Mar 29, 2009 | 05:00 AM
obscurotron's Avatar
There should be a sticker under the hood that says whether it's a 49 state or CA emission certified vehicle.
If you can beg or borrow something like a BR-3 or a ScanGauge/ScanGauge II, hook it up and find out your operating coolant temp. If it's actually low, I'd start by swapping in a new Toyota thermostat. Doing this will require you to drain some coolant, so you can change + top that off at the same time.
While it *could* be an o2 sensor, that would be last on my list. It's also possible that if it was an AZ truck, the PO ran it with NO thermostat (bad, bad idea).
1) A/F sensor
2) o2 sensor
4) low coolant
Old Mar 30, 2009 | 07:58 AM
mswenso1's Avatar
Sweet, thanks for the ideas
moparbay
Oct 6, 2015 09:24 AM
bradahman
Oct 1, 2015 09:24 AM
charlie_fong
Sep 27, 2015 10:06 PM
Odin
Sep 26, 2015 06:56 PM
Draven023
Sep 26, 2015 12:41 PM
