Optima battery questions
Old Jul 7, 2003 | 10:46 AM
rwmorrisonjr's Avatar
From: Home: Aurora, CO; Work: The People's Republic of Denver
I have two questions about the Optima batteries:
1. How do they compare to the Interstate batteries?
2. What CCA "size" do I need to get for my 3.4L in the yellow top?
Old Jul 7, 2003 | 11:34 AM
jacksonpt's Avatar
Senior Member
From what I've read/heard... Optima is gererally considered the best main stream battery available.
As near as I can tell, there are 3 versions of the yellow top available. The Group 51 offers top posts only and 500 CCA. The D34/78 offers top AND side posts, and 750CCA. The D34 offers top posts only, and 750CCA. How many CCA you'll need is dependant on what kind of gear you're running on your rig, and how often you run it. I think 500CCA is probably fine for most people... but the price difference between 500 and 750 CCA is only about $20. For the money, I'd go with the 750, but that's just me.
Old Jul 7, 2003 | 11:35 AM
jacksonpt's Avatar
Senior Member
I too have a question... what's the consensus on Yellow top fitment in 3rd gen runners, specifically a 96? I know there was a lot of debate/confusion on how to get the cables to reach - has a definitive answer been reached?
Old Jul 7, 2003 | 11:36 AM
Zubaltec's Avatar
Interstate carries them and I think they're affilated.
Old Jul 7, 2003 | 12:02 PM
transalper's Avatar
I'm not sure if this is the consensus answer, but if you want to use the stock mounting bracket with the yellow-top a 1" spacer underneath the battery is needed (the optima plastic spacer is a bit too tall). To avoid having to pull and bend the wiring, a short positive extension is needed. A slightly longer ground/body wire is also needed. That's it. It's a pretty clean set-up.
As far as CCA, the more the better as far as I'm concerned. 750 CCA in a very strong battery like th optima is plenty for around here. I live in MN so the definition of "cold" in CCA may be a bit different than you guys.
Old Jul 7, 2003 | 03:28 PM
rjm's Avatar
rjm
battery
i got a exide orbital gel deep cycle battery with four posts- has more cranking power than an optima and costs less too.
80Truck
Oct 12, 2025 07:25 PM
SubiKing
Aug 21, 2021 03:57 AM
makemusic116
Aug 2, 2015 04:40 AM
stock87yota
Jul 31, 2015 10:08 AM
mluz013
Jul 24, 2015 12:31 PM
