Optima Battery in 3rd Gen 4Runner
Old Dec 31, 2004 | 10:24 AM
Sparman's Avatar
I need to buy a new battery and would like to go with an Optima.
Can anyone with experience let me know how the fit is?
I know they have an unusual footprint.
Thanks,
Curt
Old Dec 31, 2004 | 10:48 AM
data's Avatar
Senior Member
Mine fit w\o any probs. I have a red top.
Old Dec 31, 2004 | 11:05 AM
SkyRat's Avatar
I purchased a red top and there are minor issues. All are easily solved.
I needed to bend the hold down bracket (mine came without the spacer), and some of the cables to the positive are pretty tight. Some slight re-routing can solve it all.
Old Dec 31, 2004 | 11:30 AM
Noliwan's Avatar
I'd go for the Optima Red Top 34R-- This will save you some hassles with extending your cables-- be sure to get the spacer also which is free from Optima--Just call or e-mail them--got mine within a week-- this will make the battery fit in your compartment perfectly...
You can see the spacer at the bottom of battery here... perfect fit...
Old Dec 31, 2004 | 11:47 AM
02SE's Avatar
I have a Yellow top. I did extend my cables, but I have had no problems in 7 years. This is in a '97 4Runner.
Old Dec 31, 2004 | 12:29 PM
leebee's Avatar
is the doctor in?
hey noliwan!
what time is dinner served?! that engine compartment is spotless. as for the spacer, it was included when i bought my red top. took it apart and it clipped on the bottom of the battery case. the positive cable was a bit tight, i had to replace the small ground wire from the neg to the body as the old battery had shifted and tore it away. 1/2 banana job.
lee
Old Dec 31, 2004 | 12:40 PM
Sparman's Avatar
Thanks everyone.
I'm headed to Costco to grab a red top.
Happy New Year!
Old Dec 31, 2004 | 02:12 PM
its2slo's Avatar
ahh, i think costco only caries 75/35 red tops but at the $100 price it might be worth a couple mods to make your harness fit. anything is better than a leaky battery but if you dont want to cut a couple wires you might just want the 34r. good luck. (my 75/35 works great)
Old Dec 31, 2004 | 02:15 PM
Bigblock's Avatar
hold down? spacer? in the south, we just use a bunjee strap. lol
Old Jan 1, 2005 | 06:00 AM
leebee's Avatar
check walmart
Originally Posted by Sparman
Thanks everyone.
Happy New Year!
you may want to check walmart before you buy at costco. they had the 1k & 910 red top for the same price as the base battery at costco.
lee
Old Jan 1, 2005 | 09:04 AM
midiwall's Avatar
Yeup, and if you have GI Joe's down there, then they're worth a look. $119 for the big red.
Old Jan 1, 2005 | 10:12 AM
Zachariah1023's Avatar
My battery cables are held fit witha 9 mm casing.
Old Jan 1, 2005 | 11:47 AM
Fink's Avatar
I cut up a 2x4 and made little blocks for the hold down strap to snug up to...its worked fine for almost a year now!
Fink
Old Jan 1, 2005 | 06:06 PM
Mad Chemist's Avatar
I used a couple pieces of 1/4" plywood to make a spacer for my redtop.
Old Mar 19, 2005 | 09:51 PM
calrockx's Avatar
So the red top model to get for the 3rd gen 4runner is the 34R, but which model yellow top is the right one to get?
i'm thinking i should go yellow to support aux lights, and a future inverter + winch.
Old Mar 20, 2005 | 04:26 AM
p1michaud's Avatar
Thumbs up Other options
I need to buy a new battery and would like to go with an Optima. Can anyone with experience let me know how the fit is?
Just so you know there are other options:
You can use an Optima Red Top 34/78 and modify the battery holder and cables like THIS .
or just lay the battery on it's side like THIS .
Just a word of caution, be careful using wood or other similar material as a spacer. Baja Taco said this during one of our discussions: " I know of people who have tried this with disastrous results. Vibration will work anything like that loose."
Cheers ,
P
Old Mar 20, 2005 | 07:12 AM
dragr1's Avatar
I've got the red top and it fit no problem, but the cable will be a stretch to get it on.
Old Oct 2, 2005 | 11:48 AM
xcmountain80's Avatar
Turned mine sideways and used the spacer....
Aaron
Old Oct 2, 2005 | 01:08 PM
4runner4middie's Avatar
good luck with finding oue at costco, my local store doesnt carry optima, just costco brand... i have to head over to batteries plus tomorrow to get mine.
Old Oct 2, 2005 | 01:42 PM
TACOMANATOR's Avatar
I purchased mine at Batteries Plus a few days ago for $119. They had the spacer in the back and gave it to me at no charge. 34R and a perfect fit.
