Old Man Emu Set Up
Old Man Emu Set Up
Hey everyone just one more lift question. I think I will be going with the ome set up to lift my 02 runner. My question is what spring numbers and shocks should I run? Are there different heights available?
Lastly, is the anything else needed to complete the lift?
brake line ext?
Steering stabilzer?
etc?
Thanks for the help.
Is there any other concerns I should have with lifting my truck. Driveline vibrations and cv joints should be fine with the lift if it is only about 2 inchs correct?
brake line ext?
Steering stabilzer?
etc?
the shop around here doesn't know about saws! The only thing they know about for the 4 runner is the OME's.
I guess I have one more question, anyone know of a good shop close to Toronto Canada?
I too am unhappy with the front end. When putting OME shocks/coils on each corner, my 4runner is a good 2.5" lower than the front...and after 2 months, its the same.
Now Im investing in some larger coil spacers, because the 1" spacers I got already sagged.
For the front, just get some coil spacers or if you have the money, look into the coil-overs. There's lots of options. Most are pretty expensive though. You can choose from Sway-A-Way(SAW), Camburg, Fox, Donhue, Fabtech, King, Order them online. They are easier to install too...
Originally Posted by AznSky
don't go ome in the front. You'll hate the sag. at least go with some type of coilover. SAWs will probably be your best bet (and cheapest too)
Check out my website for what I have on my 4Runner, at least for another 3 days. www.drawhorn.org and go to write-ups and look for front and rear OME.
Good luck!
Originally Posted by mycotopian
Wabbit you want to sell me your OME stuff?
Ok... I love my front setup now, and it looks like the buyer for it might be flaky... If it falls through, then I MAY keep my old setup up front and then I'd have OME fronts and Downey Rears for sale. It all depends on how it feels w/ the extra weight of the winch in there...
edit: on second thought, you may not want to run the fronts. they're 882's for 2.5" of lift WITH heavy ARB/TJM bumper w/ a winch and 4wd diff. They'd give you 4" +.... You'd need the downeys plus a 2" spacer in the rear to get it to sit level.
(on a more personal note: you're going to switch to the Tech 1's, right? Or is it still the LX450's? Why no likey the Downey's?)
*ontopic*
Front 881 Coils for safety's Sake
Rear 891 Coils
Originally Posted by gapguy
4"+? Anybody remember when I ran the 882's with no bumper? I sat completely level. I really dont think they yield THAT much lift. As it is, I'm ordering SAW's to take care of the minimal front sag, and a 1.5" spacer for the rear because I have a lot of weight in the back and it's sagging now too.
*ontopic*
Order a Diff Drop! http://www.4crawler.org
*ontopic*
Not to drag this on any farther.. But what I was getting at is the 2wd coils are shorter, thus more lift when you install a 4x4 lift coil. I'm guessing you're referring to the added weight of a front differential?
I have a 4 wd. In reality I just want to get my truck up in the air for some mild off roading and bigger tires. I looking for a cost effective way of doing it with comprimising the good luck that I have had with this vehicle up to date.
Would that mean he'd get more in the rear also?
