Oil Filter question.??
Old Jun 25, 2004 | 03:13 PM
radarski's Avatar
Question Oil Filter question.??
Hi all, recently bought a 99 4 runner & trying to change the oil filter. Can someone tell me how to locate it & the best way to get to it.? Thanks.
p.s. This forum has been a great help so far.!!
Old Jun 25, 2004 | 03:34 PM
Bob_98SR5's Avatar
radarski,
welcome to the forum
check the tech section. there's a write up addressing this very issue. in the maintenance section.
bob
Old Jun 26, 2004 | 10:46 AM
radarski's Avatar
Thumbs up Thanks Bob.
Originally Posted by Bob_98SR5
radarski,
bob
Thanks for pointing me in the right direction Bob. It seems the easiest way to the oil filter is to remove the skid plate for access.
Bit of a pain & kinda disappointing for a Toyota. Thanks again.
Old Jun 26, 2004 | 11:32 AM
My99's Avatar
You don't HAVE to remove the skidplate, you can reach up through the fenderwell and get to the filter. Downside is oil all over your skidplate. It kinda builds up a gunky mess over time. Maybe if you take it off every 3rd or 4th change and chean the skidplate, it'd be alright.
Old Jun 26, 2004 | 05:42 PM
radarski's Avatar
Thumbs up Thanks Kyle.
Thanks for the info Kyle but as I share a workshop with a mechanic I'll probably go the skidplate route. Radarski.
Old Jun 27, 2004 | 06:17 AM
Highland Runner's Avatar
I don't take the skid plate off mine or my wifes Runners. All thats needed is to reach through the wheel well after removing one plastic snap from the rubber flap. There is no need for a filter wrench either. The filter should not be more than hand tight. Turn half to 3/4 a turn after the filter seats. You may need a filter wrench and extension the first time but after that it's easy. I spray degreaser into the area that oil leaks after an oil change.
Old Jun 27, 2004 | 10:04 AM
roger's Avatar
That's what I do too. But for some reason when I switched to the Toyota filter it was a major PITA to get off, and I never tighten it more that a 3/4 past hand tight.
As for oil on the skidplate, I just deal with it. If I ever get around to banging that dent I got in Big Bend out of the skidplate, I will clean it off while I'm at it....
Eggslinger
Jun 8, 2019 03:32 PM
jasonty
41
Dec 23, 2018 01:00 PM
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
calderp
Jul 27, 2015 09:58 AM
ryerye13
Jul 14, 2015 08:27 AM
