Oil filter question?
Old Jul 21, 2003 | 05:38 AM
hillbilly's Avatar
Question Oil filter question?
Anyone ever try or have any thoughts about switching to a bigger oil filter?? I've used Wix filter for years and tend to stick with what works, so my 3.4L calls for a Wix:
Part Number: 51348
UPC Number: 765809513488
All Applications
Style: Spin-On Lube
Service: Lube
Type: Full Flow
Media: Paper
Height: 3.404
Outer Diameter Top: 2.921
Outer Diameter Bottom: Closed
Thread Size: 3/4-16
By-Pass Valve Setting-PSI: 8-11
Anti-Drain Back Valve: Yes
Gasket Diameters
Number O.D. I.D. Thk.
Attached 2.734 2.430 0.226
I talked to the local Wix guru in town and mentioned I'd like to use a bigger filter in hopes of getting more filtration (the OEM filters seem so dag small). After nosing around the back of his Wix manuals for a bit, he comes back with this:
Part Number: 51516
UPC Number: 765809515161
Principal Application: Ford Family of Cars + Trucks (81-03), Jeep (02-03), Mazda Trucks (94-03)
All Applications
Style: Spin-On Lube
Service: Lube
Type: Full Flow
Media: Paper
Height: 4.828
Thread Size: 3/4-16
Gasket Diameters
The 51516 is 25% taller when compared to the manufacturer spec'd 51348. The way I figure it, the 51516 has 25% more paper for 25% more filtration power. I visually verified outer diameters and double checked the thread sizing (definitely don't want it to work loose or fall off).
Outside of needing to add an additional ¼ to ½ quart at oil change time to compensate for the bigger filter, anyone have any thoughts (pro or con) about going with a bigger filter??
Old Jul 21, 2003 | 09:00 AM
Highland Runner's Avatar
There is nothing wrong with using a lager filter. It gives more surface area for filtering. Check out http://theoildrop.server101.com/cgi/ultimatebb.cgi? This topic has been discussed many times.
Old Jul 21, 2003 | 10:04 AM
Gadget's Avatar
I use the AMSOIL SDF-34 oil filter. It is one inch longer then the recommended SDF-57 oil filter.
Gadget
www.GadgetOnline.com
the1998sr5
15
Jul 14, 2020 08:35 PM
Eggslinger
Jun 8, 2019 03:32 PM
jasonty
41
Dec 23, 2018 01:00 PM
thefishguy77
Jul 30, 2015 10:59 AM
Coreyr384
Jul 10, 2015 11:13 AM
