Oil Cooler Guestion
Old Feb 27, 2003 | 03:51 AM
ATC's Avatar
ATC
Oil Cooler Guestion
Hello Everyone, I am a new member to the forum & have a pretty good question I believe to start out w/. I own a '95 4Runner 4x4 w/ the 3.0 V6. I have had a few head aches over the last 7,000 miles. The first one started when the #6 valve burn & I had the engine rebuilt at just under 153k. I made a few changes & added some stuff in the rebuild. One of the ad ons was a remote oil filter kit. Well about 7k late one of the oil lines came off which resulted in a 2nd rebuild (spun bearing & broken cam). The company who rebuilt the engine does not want to put the original oil cool back on due to metal contamination & I don't care for the $456.00 price tag at the dealer. I personally do not see what good it does since it relies on engine coolant to cool oil. My question is this. Has anyone ever removed the Oil Cooler from their 4Runner? One other change hich may effect this is that I also had Downey headers put on. It seems to me that the engine can now flow better & this should result in it having a cooler oil temp. Am I right in thinking this?. How Toyota ever got away w/ that factory exhaust set up is beyond me.
One other thing. How can I ad a pic of my 4Runner?
Thanks in advance for your time & help, Todd
Old Feb 27, 2003 | 05:33 AM
Firefyter-Emt's Avatar
Which oil cooler is over $400?? If it is that factory one I asay go with a used one.. (I have one I can sell you cheap ) I can not believe that those are all that expensive... But I agree, you should change it either way.. and ditch that remote crap.. That is the exact reason I hate them.. (and those stupid flip leaver drains..)
Old Feb 27, 2003 | 07:24 AM
ATC's Avatar
ATC
The oil cooler in question is the one that attaches to the block and the oil is cooled by engine coolant. The remote kit did not have a valve, but it physically moved the filter.
Old Feb 27, 2003 | 09:59 AM
Jay's Avatar
Jay
Having headers on the car, in no way will make the engine's oil cooler, IMO. Find a used part as someone already suggested, if the new one is too expensive for you.
Jay
Old Feb 27, 2003 | 03:00 PM
ATZ.. if you want it, and I pull it off my parts motor.. how about $25 + shipping? Came off a 91 x-cab with 87k
Old Feb 27, 2003 | 03:22 PM
ATC's Avatar
ATC
Hey that sounds great to me. Could you send it UPS over night? & how can I pay you for it? If you want just email me directly at atmecamp@iglou.com
Thanks
Old Feb 27, 2003 | 03:51 PM
I can send it overnight if you wish, but I can not remove it untill Saturday.. (The motor is in my dad's barn..)
Do you have PayPal??
Old Feb 27, 2003 | 04:06 PM
ATC's Avatar
ATC
Yeah I am set up w/ PayPal & Sat is fine w/ me. I will let my mechanic know that one will be on its way.
Just making sure were talking about the same part. This is the oil cooler that sits to the right of the oil filter that has 2 water lines coming out of it right?
Old Feb 27, 2003 | 05:26 PM
94 First Responder's Avatar
I rebuilt mine a few weeks ago with new seals and orings. Make sure when you disassemble your current one to take a set of lock grip pliers and block off the 2 coolant hoses that go into the cooler. This will keep you from loosing all your coolant from the radiator. I would suggest a rebuild kit from toyota. I think its like 23 bucks for the seals and orings. Once the seals dry up they tent to sweat the oil out and will make a mess under your truck even to the extent of loosing a little pressure. 1 bolt stud holds the assmbly into the block. Make sure you use a torque wrench when you install the new cooler. Good luck!
Old Feb 27, 2003 | 06:58 PM
ATC's Avatar
ATC
Thanks for the advise on rebuilding it but am putting my old one in the trash after I spun the bearing & sent bits of metal around in the engine. The guys who rebuild motors for me are afraid it could have metal in it that may find its way back into the rebuilt engine. I am hoping my mechanic will at least wait until I receive the used oil cooler before he puts the motor back in. It will be alot easier if he does.
Hey can anyone out there tell me how to post a pic of my 4Runner on the left of the screen under my user name?
Old Feb 27, 2003 | 08:20 PM
Hee.. Hee.. yes, I know what you are looking for.. Only one oil cooler on the truck.. round gold thingee with a big 'ole bolt thru it left side of the block.... 96mm in diameter
(ok.. I am guessing on that one..)
Old Feb 27, 2003 | 08:31 PM
ATC's Avatar
ATC
Yep thats the one. I'm still kinda new to the 4Runner scene (a little better than 2 years now). Saabs used to be my play toys.
Thanks again for the help.
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
this_guy
Jul 31, 2015 01:27 PM
calderp
Jul 27, 2015 09:58 AM
Coreyr384
Jul 10, 2015 11:13 AM
Snort
Jul 9, 2015 03:58 PM
