o2 sensor location
Old Jul 25, 2004 | 02:49 PM
davefj40's Avatar
o2 sensor location
have a check engine light on a 96 SR5 4runner V6 auto. read the code and it's a bad O2 sensor 1 location 1. how do i know which side this is? i'm assuming location 1 is before the cat.
also, any recomendations for where to get the replacement sensor. should i get toyota or is there a decent aftermarket one?
thanks
dave
Old Jul 25, 2004 | 03:46 PM
nightsurfride's Avatar
The 96 has 2 o2 sensors one just before the cat and one just after. You are correct that the pre-cat o2 is the sensor 1 o2. At work we always use aftermarkets with good results, but for my rig, I try to use Toyota parts in general, though it is based on feeling, not fact. I have found that more times than not, the o2 is at fault for this code on the 3rd gens, but I always check to see if the o2 is acually reading correctly an exhaust reading too lean or rich caused by some other problem upstream.
Old Jul 25, 2004 | 04:54 PM
Gadget's Avatar
The 3.4 only has one bank of sensors. So both of them are bank 1.
Bank 1 sensor 1 is the front sensor before the cat
Bank 1 sensor 2 is the second one, the one rear of the cat.
www.URDUSA.com has some kick ass prices on O2 sensors. They are real DENSO direct plug in. DENSO makes them for Toyota and is what came on your truck STOCK.
Gadget
Old Jul 25, 2004 | 10:08 PM
motorhead99's Avatar
probably one of the best priced and quality O2 you can get your hands on is definatly bosch... check out this site: http://www.toyautoparts.com/ it may be a little cheaper.
rock on,
matt
Old Jul 26, 2004 | 01:25 AM
davefj40's Avatar
thanks guys
dave
Old Jul 26, 2004 | 01:27 AM
jimbo74's Avatar
i dont like bosch in the japanese vehicles.... or much anything really... would veer towards the denso if at all possible.....
taller1
Nov 13, 2018 02:34 PM
4x4-runner
Aug 30, 2015 08:55 AM
4x4-runner
Aug 2, 2015 09:24 AM
jetspeedz
Jul 13, 2015 09:32 PM
