Not expecting this during a tune up...
http://www.napaonline.com/MasterPage...ft+Front+-+New
Again, make sure you get "NEW". There is only a $20 difference between reman and new.
From: raleigh, nc for school chapel hill, nc for home
I've never had to undo the brake assembly. I usually undo the lower ball joint (4 bolts on the bottom of the ball joint). Getting the lower ball joint back on is usually the toughest part, but a cheap bottle jack helps with that. You just have to make sure that you have the 36mm axle nut and a good breaker bar.
I'd just replace the boots, but, I am a cheap bastard...
The CV's will be fine...just clean them well.
