Not downshifting with cruise control???
Old Aug 17, 2005 | 11:04 AM
ARB4STUNNA's Avatar
I was using the cruise control this weekend and after a while it would stop down shifting when it needed to going up hills. The gas was floored and it was losing speed. After turning the cruise off, and keeping the gas floored manually it would down shift like normal. It seemed to stop down shifting on hills after any change in speed, and I would hit "resume" to get back to my set speed. After turning the cruise off and back on again it would downshift like normal again until I had to use "resume" again. Anyone else experience this problem or any ideas what might be causing this??
Thanks in advance
Old Aug 17, 2005 | 11:24 AM
rimpainter.com's Avatar
Check your cruise cable at the throttle body first. If it is too loose, it will not be floored "enough" to kick down into 2nd gear. Also, run the rig in ECT PWR if you aren't already. Let's start there...
Old Aug 17, 2005 | 11:27 AM
Flamedx4's Avatar
Also, the actuator and potentiometers in the servo get hot and lose their ability to hold full throttle - pretty typical.
Old Aug 17, 2005 | 12:16 PM
JimmyK's Avatar
hmm I was driving around in west VA this weekend, and my truck would downshift to 3rd no worries but if it ever had to go lower IE 2nd it would just kick out before shifting that low.
Old Aug 17, 2005 | 12:22 PM
It should also be noted that if the MPH drops enough, the stinking CC will shut off completely. Going up a hill and being tail-gated makes this kind of interesting...
(probably not the poster's problem, but worth mentioning)
kawazx636
Oct 6, 2021 03:03 PM
kcaudill
Oct 10, 2015 02:39 PM
Flightguy
Oct 2, 2015 05:34 PM
Shagool22
Sep 28, 2015 07:53 PM
toyotasaurus
Sep 24, 2015 03:30 PM
